楼主: sangood
[技术探讨] ESPHOME风扇改装睡眠模式,六档,按键配置请教。
发表于 2019-6-7 02:49:17 | 显示全部楼层
remote_receiver:
  pin: GPIO32
  dump: all
binary_sensor:
  - platform: remote_receiver
    name: "raw Remote Input"
    raw:
      code: [4088, -1542, 1019, -510, 513, -1019, 510, -509, 511, -510, 1020,
             -1020, 1022, -1019, 510, -509, 511, -510, 511, -509, 511, -510,
             1020, -1019, 510, -511, 1020, -510, 512, -508, 510, -1020, 1022,
             -1021, 1019, -1019, 511, -510, 510, -510, 1022, -1020, 1019,
             -1020, 511, -511, 1018, -1022, 1020, -1019, 1021, -1019, 1020,
             -511, 510, -1019, 1023, -1019, 1019, -510, 512, -508, 510, -511,
             512, -1019, 510, -509]
code里面改成你录的代码
 楼主| 发表于 2019-6-7 13:32:45 来自手机 | 显示全部楼层
hellerx 发表于 2019-6-7 02:49
remote_receiver:
  pin: GPIO32
  dump: all
我这样试了,好像没反应,再试试
发表于 2019-6-7 16:20:01 | 显示全部楼层
还能这样玩 ,厉害了
发表于 2019-6-7 21:36:49 | 显示全部楼层
sangood 发表于 2019-6-7 13:32
我这样试了,好像没反应,再试试
自己试了下,raw:有书写bug。。。。凉凉。。。。不过家里找不到raw遥控器,有个风扇是RC-Swicth-raw的,测试可以用
remote_receiver:
  pin:
    number: D5
    inverted: True
  dump: all
binary_sensor:
    name: "Fan Remote Power"
    rc_switch_raw:
      code: '11011000000'
      protocol: 4
    name: "Fan Remote Speed"
    rc_switch_raw:
      code: '11011000100'
      protocol: 4
    name: "Fan Remote mute"
    rc_switch_raw:
      code: '11011000010'
      protocol: 4
    name: "fan Remote mode"
    rc_switch_raw:
      code: '11011010000'
      protocol: 4
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-6-7 22:00:23 | 显示全部楼层
字写的不错 ,可是为什么要 装睡 呢?
发表于 2019-6-8 10:15:29 | 显示全部楼层
可惜esphome的raw ir一直都是个渣渣,可以玩玩huex合作的那个irmqtt
 楼主| 发表于 2019-6-8 20:53:03 | 显示全部楼层
hellerx 发表于 2019-6-7 21:36
自己试了下,raw:有书写bug。。。。凉凉。。。。不过家里找不到raw遥控器,有个风扇是RC-Swicth-raw的, ...
INFO Reading configuration...
INFO Generating C++ source...
  File "/usr/local/bin/esphome", line 11, in <module>
    load_entry_point('esphome==1.14.0.dev0', 'console_scripts', 'esphome')()
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/__main__.py", line 487, in main
    return run_esphome(sys.argv)
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/__main__.py", line 477, in run_esphome
    return POST_CONFIG_ACTIONS[args.command](args, config)
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/__main__.py", line 302, in command_run
    exit_code = write_cpp(config)
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/__main__.py", line 147, in write_cpp
    CORE.flush_tasks()
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/core.py", line 616, in flush_tasks
    next(task)
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/core.py", line 421, in _wrapper_generator
    for x in var:
    for x in var:
    for x in var:
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/core.py", line 409, in _wrapper_generator
    yield func(*args, **kwargs)
  File "/usr/local/lib/python2.7/site-packages/esphome-1.14.0.dev0-py2.7.egg/esphome/components/remote_base/__init__.py", line 353, in raw_binary_sensor
    arr = cg.progmem_array(config[CONF_ID], code_)
KeyError: 'id'
可能是我的raw太长了?
发表于 2019-6-9 15:15:17 | 显示全部楼层
不是,系统bug,去个otto提交个问题吧,我用10段的raw也是报id错误,应该是raw本体有问题
佑桑
发表于 2019-6-12 10:53:55 | 显示全部楼层
這篇給了我更多啟發, 一定要收藏起來
发表于 2019-6-15 12:56:59 | 显示全部楼层
https://github.com/esphome/esphome/releases
好了,你的问题修复了,试试看行不
GMT+8, 2025-12-20 00:29 , Processed in 0.862807 second(s), 6 queries , MemCached On.
