查看: 5433|回复: 4
iPhone 无法配对ha
发表于 2019-6-4 11:27:41 | 显示全部楼层 |阅读模式
路由器OpenWrt上安装hass0.93.2,接入iPhone 家庭APP时显示:
Couldn't add Home Assistant. Home couldn't connect to this accessory
homekit ip_address 改了之后没有任何变化。部分日志如下:
May 03 07:45:49 home hass[610]: 2018-05-03 07:45:49 DEBUG (MainThread) [pyhap.characteristic] Name: Set value to Home Assistant
May 03 07:45:49 home hass[610]: 2018-05-03 07:45:49 DEBUG (MainThread) [pyhap.characteristic] Model: Set value to homekit.bridge
May 03 07:45:49 home hass[610]: 2018-05-03 07:45:49 DEBUG (MainThread) [pyhap.characteristic] Manufacturer: Set value to HomeAssistant
May 03 07:45:49 home hass[610]: 2018-05-03 07:45:49 DEBUG (MainThread) [pyhap.characteristic] SerialNumber: Set value to 0000
May 03 07:45:49 home hass[610]: 2018-05-03 07:45:49 INFO (MainThread) [pyhap.accessory_driver] Storing Accessory state in `/root/.homeassistant/.homekit.state`
^OMay 03 07:46:06 home hass[610]: 2018-05-03 07:46:06 INFO (SyncWorker_7) [homeassistant.components.homekit.util] Pincode: 572-38-271
May 03 07:46:06 home hass[610]: 2018-05-03 07:46:06 DEBUG (SyncWorker_7) [homeassistant.components.homekit] Driver start
May 03 07:46:06 home hass[610]: 2018-05-03 07:46:06 INFO (SyncWorker_7) [pyhap.accessory_driver] Starting accessory 'Home Assistant' on address '10.101.199.241', port '51827'.
May 03 07:46:10 home hass[610]: 2018-05-03 07:46:10 INFO (Thread-12) [pyhap.hap_server] Got connection with ('10.101.199.242', 58062).
May 03 07:46:10 home hass[610]: 2018-05-03 07:46:10 DEBUG (Thread-13) [pyhap.hap_server] Request POST from address '('10.101.199.242', 58062)' for path '/pair-setup'.
May 03 07:46:10 home hass[610]: 2018-05-03 07:46:10 DEBUG (Thread-13) [pyhap.hap_server] Pairing [1/5]
May 03 07:46:10 home hass[610]: 2018-05-03 07:46:10 INFO (Thread-13) [pyhap.hap_server] 10.101.199.242 - "POST /pair-setup HTTP/1.1" 200 -
May 03 07:46:22 home hass[610]: 2018-05-03 07:46:22 DEBUG (Thread-13) [pyhap.hap_server] Request POST from address '('10.101.199.242', 58062)' for path '/pair-setup'.
May 03 07:46:22 home hass[610]: 2018-05-03 07:46:22 DEBUG (Thread-13) [pyhap.hap_server] Pairing [2/5]
May 03 07:46:22 home hass[610]: 2018-05-03 07:46:22 INFO (Thread-13) [pyhap.hap_server] 10.101.199.242 - "POST /pair-setup HTTP/1.1" 200 -
May 03 07:46:26 home hass[610]: 2018-05-03 07:46:26 DEBUG (Thread-13) [pyhap.hap_server] Request POST from address '('10.101.199.242', 58062)' for path '/pair-setup'.
May 03 07:46:26 home hass[610]: 2018-05-03 07:46:26 DEBUG (Thread-13) [pyhap.hap_server] Pairing [3/5]
May 03 07:46:26 home hass[610]: 2018-05-03 07:46:26 DEBUG (Thread-13) [pyhap.hap_server] Pairing [4/5]
May 03 07:46:26 home hass[610]: 2018-05-03 07:46:26 DEBUG (Thread-13) [pyhap.hap_server] Pairing [5/5]
May 03 07:46:26 home hass[610]: 2018-05-03 07:46:26 INFO (Thread-13) [pyhap.accessory_driver] Paired with 11111111-2222-3333-44444-000000000000.
求教。。。。。
发表于 2019-6-4 14:25:25 | 显示全部楼层
It might be necessary to install an additional package: $ sudo apt-get install libavahi-compat-libdnssd-dev
不知道对你有没有帮助
 楼主| 发表于 2019-6-4 15:22:18 来自手机 | 显示全部楼层
情非殇 发表于 2019-6-4 14:25
It might be necessary to install an additional package: $ sudo apt-get install libavahi-compat-libdn ...
我是OpenWrt,我找找有没有对应的包,多谢
发表于 2019-6-4 15:43:32 | 显示全部楼层
不晓得哦,这个官方文档里写的,docker里面就不用,
而且,说实话我不确定是不是这个问题影响你的哟
 楼主| 发表于 2019-6-4 16:02:48 来自手机 | 显示全部楼层
而且,说实话我不确定是不是这个问题影响你的哟 ...
死马当活马医了
GMT+8, 2026-1-1 17:55 , Processed in 0.099821 second(s), 13 queries , MemCached On.
