查看: 5577|回复: 3
[流程系列] nodered安装时候出现的问题
发表于 2019-6-2 18:25:19 | 显示全部楼层 |阅读模式
[color=var(--paper-card-header-color, #000)]Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.[s6-init] ensuring user provided files have correct perms...exited 0.[fix-attrs.d] applying ownership & permissions fixes...[fix-attrs.d] done.[cont-init.d] executing container initialization scripts...[cont-init.d] 00-banner.sh: executing... ----------------------------------------------------------- Hass.io Add-on: Node-RED Flow-based programming for the Internet of Things----------------------------------------------------------- Add-on version: 3.1.1 You are running the latest version of this add-on. System: HassOS 3.1  (armv7 / raspberrypi3) Home Assistant version: 0.93.1 Supervisor version: 165----------------------------------------------------------- Please, share the above information when looking for help or support in, e.g., GitHub, forums or the Discord chat.-----------------------------------------------------------[cont-init.d] 00-banner.sh: exited 0.[cont-init.d] 01-log-level.sh: executing... [cont-init.d] 01-log-level.sh: exited 0.[cont-init.d] nginx.sh: executing... [18:22:59] FATAL: [18:22:59] FATAL: SSL has been enabled using the 'ssl' option,[18:22:59] FATAL: this requires a SSL certificate file which is[18:22:59] FATAL: configured using the 'certfile' option in the[18:22:59] FATAL: add-on configuration.[18:22:59] FATAL: [18:22:59] FATAL: Unfortunately, the file specified in the[18:22:59] FATAL: 'certfile' option does not exists.[18:22:59] FATAL: [18:22:59] FATAL: Please ensure the certificate file exists and[18:22:59] FATAL: is placed in the Hass.io '/ssl/' directory.[18:22:59] FATAL: [18:22:59] FATAL: In case you don't have SSL yet, consider getting[18:22:59] FATAL: a SSL certificate or setting the 'ssl' option[18:22:59] FATAL: to 'false' in case you are not planning on using[18:22:59] FATAL: SSL with this add-on.[18:22:59] FATAL: [18:22:59] FATAL: Check the add-on manual for more information.[18:22:59] FATAL: [cont-init.d] nginx.sh: exited 1.[cont-finish.d] executing container finish scripts...[cont-finish.d] 99-message.sh: executing... -----------------------------------------------------------                Oops! Something went wrong. We are so sorry, but something went terribly wrong when starting or running this add-on. Be sure to check the log above, line by line, for hints.-----------------------------------------------------------[cont-finish.d] 99-message.sh: exited 0.[cont-finish.d] done.[s6-finish] waiting for services.[s6-finish] sending all processes the TERM signal.
安装已经好了 无法启动 日志如上 现在还没有找到解决办法
流水无味
灌水之王
发表于 2019-6-3 07:58:26 | 显示全部楼层
SSL?    这样的记录看的一脸懵逼
发表于 2019-6-4 08:53:25 | 显示全部楼层
SSL 选项设置成 false
 楼主| 发表于 2019-6-9 12:05:12 | 显示全部楼层
已经解决 谢谢大家
GMT+8, 2025-12-24 17:22 , Processed in 0.558060 second(s), 10 queries , MemCached On.
