查看: 2160|回复: 2
论坛一键HASS.IO安装完毕启动不了?
发表于 2019-6-1 09:38:19 | 显示全部楼层 |阅读模式
########################### Docker images ###########################
REPOSITORY                                 TAG                 IMAGE ID            CREATED             SIZE
homeassistant/raspberrypi3-homeassistant   0.93.2              fef041df9d48        8 days ago          970MB
homeassistant/raspberrypi3-homeassistant   latest              fef041df9d48        8 days ago          970MB
homeassistant/armhf-hassio-supervisor      164                 df9d486aa773        13 days ago         183MB
homeassistant/armhf-hassio-supervisor      latest              df9d486aa773        13 days ago         183MB
########################### Docker ps ###########################
CONTAINER ID        IMAGE                                   COMMAND               CREATED             STATUS              PORTS    NAMES
8ad43e5641a5        homeassistant/armhf-hassio-supervisor   "python3 -m hassio"   5 minutes ago       Up 4 minutes    hassio_supervisor
########################### hassio log ###########################
19-06-01 00:59:27 INFO (MainThread) [__main__] Initialize Hass.io setup
19-06-01 00:59:27 INFO (MainThread) [hassio.docker.network] Can't find Hass.io network, create new network
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
19-06-01 00:59:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Apparmor folder /data/apparmor
19-06-01 00:59:27 INFO (MainThread) [__main__] Setup HassIO
19-06-01 00:59:27 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 164
19-06-01 00:59:27 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-06-01 00:59:29 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-06-01 00:59:29 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-06-01 00:59:29 INFO (MainThread) [hassio.host.info] Update local host information
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-06-01 00:59:29 INFO (MainThread) [hassio.host.services] Update service information
19-06-01 00:59:29 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-06-01 00:59:29 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-06-01 00:59:29 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-06-01 00:59:29 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.93.2
19-06-01 00:59:29 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
19-06-01 00:59:30 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/hassio-addons/repository repository
19-06-01 01:04:02 INFO (MainThread) [hassio.store] Load add-ons from store: 59 all - 59 new - 0 remove
19-06-01 01:04:02 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
19-06-01 01:04:02 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-06-01 01:04:04 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
19-06-01 01:04:04 INFO (MainThread) [hassio.discovery] Load 0 messages
19-06-01 01:04:04 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-06-01 01:04:04 INFO (MainThread) [__main__] Run Hass.io
19-06-01 01:04:04 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-06-01 01:04:04 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 165
19-06-01 01:04:04 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/armhf-hassio-supervisor tag 165.
########################### homeassistant log ###########################
Error: No such container: homeassistant
homeassistant 启动超时,请检查上方日志....
流水无味
灌水之王
发表于 2019-6-1 09:48:12 | 显示全部楼层
感觉没拉成功?被墙?
重来一次 一键安装换源安装
发表于 2019-7-5 19:55:18 | 显示全部楼层
蛤蟆跳井 噗通
GMT+8, 2026-1-1 13:54 , Processed in 1.131042 second(s), 9 queries , MemCached On.
