查看: 2885|回复: 7
[技术探讨] 博联 sensor 跟switch 报错 紧急求援!!!
发表于 2019-5-31 22:15:40 | 显示全部楼层 |阅读模式
突然显示
The following components and platforms could not be set up:
  • broadlink.sensor
  • broadlink.switch
Please check your config.
看不懂啥问题啊,哪位大侠知道怎么解决?
Unable to install package broadlink==0.10.0: ERROR: Complete output from command /usr/local/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-u74ey7eq/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-7zcm339g --python-tag cp37:  ERROR: Testing support for clang  Target does not support clang  Testing support for gcc  Target does not support gcc  Testing support for stdint.h header  Target does not support stdint.h header  Testing support for 128-bit integer  Target does not support 128-bit integer  Testing support for intrin.h header  Target does not support intrin.h header  Testing support for cpuid.h header  Target does not support cpuid.h header  Testing support for posix_memalign  Target does not support posix_memalign  Testing support for memalign  Target does not support memalign  Warning: compiler does not support AESNI instructions  Warning: compiler does not support CLMUL instructions  running bdist_wheel  running build  running build_py  creating build/lib.linux-armv7l-3.7  creating build/lib.linux-armv7l-3.7/Crypto  copying lib/Crypto/__init__.py -> build/lib.linux-armv7l-3.7/Crypto  creating build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_gcm.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_openpgp.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_cfb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/Salsa20.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ARC2.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/CAST.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_eax.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/AES.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ccm.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ecb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ctr.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/PKCS1_OAEP.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ocb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ChaCha20_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ofb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/DES3.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_siv.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/Blowfish.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ChaCha20.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/PKCS1_v1_5.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/DES.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_cbc.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ARC4.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher  creating build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_512.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA224.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD2.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/HMAC.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA1.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHAKE256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_384.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHAKE128.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA384.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/BLAKE2b.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD5.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/RIPEMD.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/RIPEMD160.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/keccak.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/BLAKE2s.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA512.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_224.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/CMAC.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD4.py -> build/lib.linux-armv7l-3.7/Crypto/Hash  creating build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/_PBES.py -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/PKCS8.py -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/PEM.py -> build/lib.linux-armv7l-3.7/Crypto/IO  creating build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/ElGamal.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/DSA.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/ECC.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/RSA.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  creating build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Protocol/SecretSharing.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Protocol/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Protocol/KDF.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol  creating build/lib.linux-armv7l-3.7/Crypto/Random  copying lib/Crypto/Random/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Random  copying lib/Crypto/Random/random.py -> build/lib.linux-armv7l-3.7/Crypto/Random  creating build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/DSS.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/PKCS1_PSS.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/pss.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/PKCS1_v1_5.py -> build/lib.linux-armv7l-3.7/Crypto/Signature  creating build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/Counter.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/strxor.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/Padding.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/number.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/_cpu_features.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/_file_system.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/_raw_api.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/py3compat.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/RFC1751.py -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/asn1.py -> build/lib.linux-armv7l-3.7/Crypto/Util  creating build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/Primality.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerCustom.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerGMP.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerBase.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/Numbers.py -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerNative.py -> build/lib.linux-armv7l-3.7/Crypto/Math  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest  copying lib/Crypto/SelfTest/st_common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest  copying lib/Crypto/SelfTest/__main__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest  copying lib/Crypto/SelfTest/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest  copying lib/Crypto/SelfTest/loader.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_DES3.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_CCM.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_pkcs1_oaep.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_CTR.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_Blowfish.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_ARC2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_ChaCha20_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_ARC4.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_ChaCha20.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_OFB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_CFB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_CBC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_CAST.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_OCB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_SIV.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_OpenPGP.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_AES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_Salsa20.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_EAX.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_GCM.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  copying lib/Crypto/SelfTest/Cipher/test_DES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA256.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_MD2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA1.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_keccak.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHAKE.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_RIPEMD160.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_CMAC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA224.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_BLAKE2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA3_256.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA3_384.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_MD5.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_MD4.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA3_512.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA384.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA3_224.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_SHA512.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  copying lib/Crypto/SelfTest/Hash/test_HMAC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO  copying lib/Crypto/SelfTest/IO/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO  copying lib/Crypto/SelfTest/IO/test_PBES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO  copying lib/Crypto/SelfTest/IO/test_PKCS8.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol  copying lib/Crypto/SelfTest/Protocol/test_KDF.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol  copying lib/Crypto/SelfTest/Protocol/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol  copying lib/Crypto/SelfTest/Protocol/test_rfc1751.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol  copying lib/Crypto/SelfTest/Protocol/test_SecretSharing.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_ECC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_import_ECC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_import_RSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_RSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_import_DSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_ElGamal.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  copying lib/Crypto/SelfTest/PublicKey/test_DSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random  copying lib/Crypto/SelfTest/Random/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random  copying lib/Crypto/SelfTest/Random/test_random.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature  copying lib/Crypto/SelfTest/Signature/test_dss.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature  copying lib/Crypto/SelfTest/Signature/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature  copying lib/Crypto/SelfTest/Signature/test_pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature  copying lib/Crypto/SelfTest/Signature/test_pss.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/test_strxor.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/test_number.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/test_asn1.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/test_Counter.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  copying lib/Crypto/SelfTest/Util/test_Padding.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math  copying lib/Crypto/SelfTest/Math/test_Primality.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math  copying lib/Crypto/SelfTest/Math/test_Numbers.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math  copying lib/Crypto/SelfTest/Math/test_modexp.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math  copying lib/Crypto/SelfTest/Math/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math  copying lib/Crypto/py.typed -> build/lib.linux-armv7l-3.7/Crypto  copying lib/Crypto/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto  copying lib/Crypto/Cipher/Salsa20.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ARC4.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ccm.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_cbc.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_cfb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_gcm.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ARC2.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ecb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/DES3.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/PKCS1_v1_5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/PKCS1_OAEP.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ChaCha20_Poly1305.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/ChaCha20.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ocb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/DES.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_eax.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/Blowfish.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ofb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_openpgp.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/AES.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_siv.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/_mode_ctr.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Cipher/CAST.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher  copying lib/Crypto/Hash/Poly1305.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/keccak.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD4.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/CMAC.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/RIPEMD.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/HMAC.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA1.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_512.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/BLAKE2b.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA384.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_384.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA224.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA3_224.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/BLAKE2s.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/MD2.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/RIPEMD160.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHAKE256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHAKE128.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/Hash/SHA512.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash  copying lib/Crypto/IO/PEM.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/_PBES.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/IO/PKCS8.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO  copying lib/Crypto/PublicKey/DSA.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/ECC.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/ElGamal.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/RSA.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/PublicKey/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey  copying lib/Crypto/Protocol/SecretSharing.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Protocol/KDF.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Protocol/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol  copying lib/Crypto/Random/random.pyi -> build/lib.linux-armv7l-3.7/Crypto/Random  copying lib/Crypto/Random/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Random  copying lib/Crypto/Signature/PKCS1_PSS.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/DSS.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/PKCS1_v1_5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/pkcs1_15.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Signature/pss.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature  copying lib/Crypto/Util/_file_system.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/Padding.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/RFC1751.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/py3compat.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/asn1.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/Counter.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/_cpu_features.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/number.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/_raw_api.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Util/strxor.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util  copying lib/Crypto/Math/_IntegerCustom.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/Numbers.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerNative.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/Primality.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerGMP.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  copying lib/Crypto/Math/_IntegerBase.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMCT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MCT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128KeySbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarTxt192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCKeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMMT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCKeySbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBKeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarKey192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarTxt128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8GFSbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MCT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarTxt128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMCT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128KeySbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/gcmEncryptExtIV128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBGFSbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128KeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8GFSbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCGFSbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMMT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MMT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128GFSbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarTxt128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarKey128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/gcmDecrypt128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarTxt256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MCT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarKey128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MCT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMCT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMCT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarTxt192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarKey192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MCT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMCT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128GFSbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMMT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/README.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMMT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarTxt192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8KeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBKeySbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8KeySbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarTxt192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBGFSbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCKeySbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarKey192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MCT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128VarKey128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MMT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarTxt128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarKey128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBGFSbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8GFSbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCGFSbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarTxt256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MMT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128GFSbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MMT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarTxt256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128MMT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarKey192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMMT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCGFSbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMMT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBKeySbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarTxt256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8KeySbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMCT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MMT192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TECBMMT3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8invperm.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCpermop.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64vartext.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64invperm.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCMMT3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64varkey.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8vartext.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBvarkey.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8varkey.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCinvperm.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBMMT2.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBvartext.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBsubtab.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8MMT2.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64subtab.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8permop.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBinvperm.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/README.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8MMT3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCvarkey.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBpermop.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCvartext.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64permop.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64MMT2.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TOFBMMT3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB64MMT3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TECBMMT2.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCMMT2.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCBCsubtab.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  copying lib/Crypto/SelfTest/Cipher/test_vectors/TDES/TCFB8subtab.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/TDES  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Cipher/test_vectors/wycheproof/aes_siv_cmac_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Cipher/test_vectors/wycheproof/aes_gcm_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Cipher/test_vectors/wycheproof/aes_eax_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Cipher/test_vectors/wycheproof/chacha20_poly1305_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/wycheproof  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA1  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA1/SHA1ShortMsg.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA1  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA2  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA2/SHA512ShortMsg.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA2  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA2/SHA512_224ShortMsg.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA2  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA2/SHA512_256ShortMsg.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA2  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHA3-224.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHA3-384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHA3-512.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHAKE128.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHA3-256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  copying lib/Crypto/SelfTest/Hash/test_vectors/SHA3/ShortMsgKAT_SHAKE256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/SHA3  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ExtremelyLongMsgKAT_224.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ShortMsgKAT_512.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ShortMsgKAT_384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ShortMsgKAT_224.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ExtremelyLongMsgKAT_512.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ExtremelyLongMsgKAT_384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/LongMsgKAT_384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/readme.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/LongMsgKAT_256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/LongMsgKAT_512.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ExtremelyLongMsgKAT_256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/ShortMsgKAT_256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  copying lib/Crypto/SelfTest/Hash/test_vectors/keccak/LongMsgKAT_224.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/keccak  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2s  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2s/tv1.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2s  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2s/tv2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2s  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2s/blake2s-test.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2s  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2b  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2b/blake2b-test.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2b  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2b/tv1.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2b  copying lib/Crypto/SelfTest/Hash/test_vectors/BLAKE2b/tv2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/BLAKE2b  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Hash/test_vectors/wycheproof/aes_cmac_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash/test_vectors/wycheproof  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_p8.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_enc_des3.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/point-at-infinity.org-P384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_enc_aes256_gcm.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_p8_clear.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_public_compressed.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_enc_aes128.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/gen_ecc_p384.sh -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_p8.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_public.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_p8_clear.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/openssl_version_p521.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_public_compressed.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public_openssh.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/gen_ecc_p521.sh -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_x509.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_ecparams.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_enc_aes256_gcm.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_enc_aes128.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_x509.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_p8.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_p8.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_p8.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/openssl_version_p384.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/gen_ecc_p256.sh -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_enc_aes128.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_p8_clear.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_x509.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_p8_clear.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_public_openssh.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/point-at-infinity.org-P256.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_public_compressed.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_enc_aes192.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/openssl_version.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_enc_des3.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_enc_aes256_gcm.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_public.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_public_compressed.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_enc_aes192.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_p8_clear.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_p8.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/point-at-infinity.org-P521.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_public.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_public.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_x509.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_public_openssh.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p521_private_p8_clear.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public_compressed.der -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_private_enc_des3.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p384_x509.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_public_compressed.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_x509.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_enc_aes192.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA  copying lib/Crypto/SelfTest/Signature/test_vectors/DSA/FIPS_186_3_SigGen.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA  copying lib/Crypto/SelfTest/Signature/test_vectors/DSA/FIPS_186_3_SigVer.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA  copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/SigVer.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA  copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/README.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA  copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/SigGen.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigVer15_186-3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigGen15_186-2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigGen15_186-3.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigVerPSS_186-3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigGenPSS_186-3.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS  copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigGenPSS_186-2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS  creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_4096_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_3072_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp384r1_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp256r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp521r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp384r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp256r1_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha224_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha256_mgf1_0_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_4096_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_4096_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha1_mgf1_20_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/dsa_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_4096_sha512_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_misc_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof  running build_ext  building 'Crypto.Hash._MD2' extension  creating build/temp.linux-armv7l-3.7  creating build/temp.linux-armv7l-3.7/src  gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DPYCRYPTO_LITTLE_ENDIAN -DSYS_BITS=32 -DLTC_NO_ASM -Isrc/ -I/usr/local/include/python3.7m -c src/MD2.c -o build/temp.linux-armv7l-3.7/src/MD2.o  unable to execute 'gcc': No such file or directory  error: command 'gcc' failed with exit status 1  ----------------------------------------  ERROR: Failed building wheel for pycryptodomeERROR: broadlink 0.10 has requirement pycryptodome==3.6.6, but you'll have pycryptodome 3.8.2 which is incompatible.ERROR: python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you'll have pycryptodome 3.8.2 which is incompatible.ERROR: pyrebase4 4.3.0 has requirement oauth2client==4.1.2, but you'll have oauth2client 4.0.0 which is incompatible.    ERROR: Complete output from command /usr/local/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-u74ey7eq/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-skgj6xgt/install-record.txt --single-version-externally-managed --prefix '' --compile --user --prefix=:    ERROR: Testing support for clang    Target does not support clang    Testing support for gcc    Target does not support gcc    Testing support for stdint.h header    Target does not support stdint.h header    Testing support for 128-bit integer    Target does not support 128-bit integer    Testing support for intrin.h header    Target does not support intrin.h header    Testing support for cpuid.h header    Target does not support cpuid.h header    Testing support for posix_memalign    Target does not support posix_memalign    Testing support for memalign    Target does not support memalign    Warning: compiler does not support AESNI instructions    Warning: compiler does not support CLMUL instructions    running install    running build    running build_py    creating build/lib.linux-armv7l-3.7    creating build/lib.linux-armv7l-3.7/Crypto    copying lib/Crypto/__init__.py -> build/lib.linux-armv7l-3.7/Crypto    creating build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_gcm.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_openpgp.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_cfb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/Salsa20.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ARC2.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/CAST.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_eax.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/AES.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ccm.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ecb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ctr.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/PKCS1_OAEP.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ocb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ChaCha20_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ofb.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/DES3.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_siv.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/Blowfish.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ChaCha20.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/PKCS1_v1_5.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/DES.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_cbc.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ARC4.py -> build/lib.linux-armv7l-3.7/Crypto/Cipher    creating build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_512.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA224.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD2.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/HMAC.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA1.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHAKE256.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_384.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHAKE128.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA384.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/BLAKE2b.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD5.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/RIPEMD.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/RIPEMD160.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/keccak.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/BLAKE2s.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA512.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_224.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/CMAC.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD4.py -> build/lib.linux-armv7l-3.7/Crypto/Hash    creating build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/_PBES.py -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/PKCS8.py -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/PEM.py -> build/lib.linux-armv7l-3.7/Crypto/IO    creating build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/ElGamal.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/DSA.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/ECC.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/RSA.py -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    creating build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Protocol/SecretSharing.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Protocol/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Protocol/KDF.py -> build/lib.linux-armv7l-3.7/Crypto/Protocol    creating build/lib.linux-armv7l-3.7/Crypto/Random    copying lib/Crypto/Random/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Random    copying lib/Crypto/Random/random.py -> build/lib.linux-armv7l-3.7/Crypto/Random    creating build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/DSS.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/PKCS1_PSS.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/pss.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/PKCS1_v1_5.py -> build/lib.linux-armv7l-3.7/Crypto/Signature    creating build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/Counter.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/strxor.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/Padding.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/number.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/_cpu_features.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/_file_system.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/_raw_api.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/py3compat.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/RFC1751.py -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/asn1.py -> build/lib.linux-armv7l-3.7/Crypto/Util    creating build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/Primality.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerCustom.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerGMP.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerBase.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/Numbers.py -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerNative.py -> build/lib.linux-armv7l-3.7/Crypto/Math    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest    copying lib/Crypto/SelfTest/st_common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest    copying lib/Crypto/SelfTest/__main__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest    copying lib/Crypto/SelfTest/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest    copying lib/Crypto/SelfTest/loader.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_DES3.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_CCM.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_pkcs1_oaep.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_CTR.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_Blowfish.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_ARC2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_ChaCha20_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_ARC4.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_ChaCha20.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_OFB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_CFB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_CBC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_CAST.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_OCB.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_SIV.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_OpenPGP.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_AES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_Salsa20.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_EAX.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_GCM.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    copying lib/Crypto/SelfTest/Cipher/test_DES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA256.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_MD2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA1.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_keccak.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHAKE.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/common.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_RIPEMD160.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_CMAC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA224.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_BLAKE2.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA3_256.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA3_384.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_MD5.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_MD4.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_Poly1305.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA3_512.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA384.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA3_224.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_SHA512.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    copying lib/Crypto/SelfTest/Hash/test_HMAC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Hash    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO    copying lib/Crypto/SelfTest/IO/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO    copying lib/Crypto/SelfTest/IO/test_PBES.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO    copying lib/Crypto/SelfTest/IO/test_PKCS8.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/IO    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol    copying lib/Crypto/SelfTest/Protocol/test_KDF.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol    copying lib/Crypto/SelfTest/Protocol/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol    copying lib/Crypto/SelfTest/Protocol/test_rfc1751.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol    copying lib/Crypto/SelfTest/Protocol/test_SecretSharing.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Protocol    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_ECC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_import_ECC.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_import_RSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_RSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_import_DSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_ElGamal.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    copying lib/Crypto/SelfTest/PublicKey/test_DSA.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random    copying lib/Crypto/SelfTest/Random/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random    copying lib/Crypto/SelfTest/Random/test_random.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Random    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature    copying lib/Crypto/SelfTest/Signature/test_dss.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature    copying lib/Crypto/SelfTest/Signature/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature    copying lib/Crypto/SelfTest/Signature/test_pkcs1_15.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature    copying lib/Crypto/SelfTest/Signature/test_pss.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/test_strxor.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/test_number.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/test_asn1.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/test_Counter.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    copying lib/Crypto/SelfTest/Util/test_Padding.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Util    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math    copying lib/Crypto/SelfTest/Math/test_Primality.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math    copying lib/Crypto/SelfTest/Math/test_Numbers.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math    copying lib/Crypto/SelfTest/Math/test_modexp.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math    copying lib/Crypto/SelfTest/Math/__init__.py -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Math    copying lib/Crypto/py.typed -> build/lib.linux-armv7l-3.7/Crypto    copying lib/Crypto/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto    copying lib/Crypto/Cipher/Salsa20.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ARC4.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ccm.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_cbc.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_cfb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_gcm.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ARC2.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ecb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/DES3.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/PKCS1_v1_5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/PKCS1_OAEP.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ChaCha20_Poly1305.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/ChaCha20.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ocb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/DES.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_eax.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/Blowfish.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ofb.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_openpgp.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/AES.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_siv.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/_mode_ctr.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Cipher/CAST.pyi -> build/lib.linux-armv7l-3.7/Crypto/Cipher    copying lib/Crypto/Hash/Poly1305.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/keccak.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD4.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/CMAC.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/RIPEMD.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/HMAC.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA1.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_512.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/BLAKE2b.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA384.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_384.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA224.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA3_224.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/BLAKE2s.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/MD2.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/RIPEMD160.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHAKE256.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHAKE128.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/Hash/SHA512.pyi -> build/lib.linux-armv7l-3.7/Crypto/Hash    copying lib/Crypto/IO/PEM.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/_PBES.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/IO/PKCS8.pyi -> build/lib.linux-armv7l-3.7/Crypto/IO    copying lib/Crypto/PublicKey/DSA.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/ECC.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/ElGamal.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/RSA.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/PublicKey/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/PublicKey    copying lib/Crypto/Protocol/SecretSharing.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Protocol/KDF.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Protocol/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Protocol    copying lib/Crypto/Random/random.pyi -> build/lib.linux-armv7l-3.7/Crypto/Random    copying lib/Crypto/Random/__init__.pyi -> build/lib.linux-armv7l-3.7/Crypto/Random    copying lib/Crypto/Signature/PKCS1_PSS.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/DSS.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/PKCS1_v1_5.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/pkcs1_15.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Signature/pss.pyi -> build/lib.linux-armv7l-3.7/Crypto/Signature    copying lib/Crypto/Util/_file_system.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/Padding.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/RFC1751.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/py3compat.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/asn1.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/Counter.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/_cpu_features.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/number.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/_raw_api.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Util/strxor.pyi -> build/lib.linux-armv7l-3.7/Crypto/Util    copying lib/Crypto/Math/_IntegerCustom.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/Numbers.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerNative.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/Primality.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerGMP.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    copying lib/Crypto/Math/_IntegerBase.pyi -> build/lib.linux-armv7l-3.7/Crypto/Math    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCVarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCMCT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8MCT256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB128KeySbox192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarKey256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CFB8VarTxt192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCKeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBMMT128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/CBCKeySbox128.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBKeySbox256.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/Cipher/test_vectors/AES/OFBVarKey192.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Cipher/test_vectors/AES    copying lib/Crypto/SelfTest/PublicKey/test_vectors/ECC/ecc_p256_private_enc_aes192.pem -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/PublicKey/test_vectors/ECC    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA    copying lib/Crypto/SelfTest/Signature/test_vectors/DSA/FIPS_186_3_SigGen.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA    copying lib/Crypto/SelfTest/Signature/test_vectors/DSA/FIPS_186_3_SigVer.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/DSA    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA    copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/SigVer.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA    copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/README.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA    copying lib/Crypto/SelfTest/Signature/test_vectors/ECDSA/SigGen.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/ECDSA    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigVer15_186-3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigGen15_186-2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5/SigGen15_186-3.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-v1.5    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigVerPSS_186-3.rsp -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigGenPSS_186-3.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS    copying lib/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS/SigGenPSS_186-2.txt -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/PKCS1-PSS    creating build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_4096_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_3072_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp384r1_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp256r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp521r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp384r1_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp256r1_sha256_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha224_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha256_mgf1_0_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_4096_sha256_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_4096_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_2048_sha1_mgf1_20_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha384_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/dsa_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_4096_sha512_mgf1_32_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_3072_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_pss_misc_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_2048_sha512_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_test.json -> build/lib.linux-armv7l-3.7/Crypto/SelfTest/Signature/test_vectors/wycheproof    running build_ext    building 'Crypto.Hash._MD2' extension    creating build/temp.linux-armv7l-3.7    creating build/temp.linux-armv7l-3.7/src    gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -DPYCRYPTO_LITTLE_ENDIAN -DSYS_BITS=32 -DLTC_NO_ASM -Isrc/ -I/usr/local/include/python3.7m -c src/MD2.c -o build/temp.linux-armv7l-3.7/src/MD2.o    unable to execute 'gcc': No such file or directory    error: command 'gcc' failed with exit status 1    ----------------------------------------ERROR: Command "/usr/local/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-u74ey7eq/pycryptodome/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-skgj6xgt/install-record.txt --single-version-externally-managed --prefix '' --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-u74ey7eq/pycryptodome/
发表于 2019-5-31 23:48:55 | 显示全部楼层
回忆一下报错之前进行了什么操作的?就知道原因了
发表于 2019-6-1 01:43:12 | 显示全部楼层
退回去,官方broadlink插件升级到0.10.0,系统没跟上,自定义的插件还在0.9.0还是正常的,等第三版更新应该解决了,还有一种方式,把broadlink插件放到custom_components里,版本改成0.9.0即可,自定义插件会优先内置插件
刚查看了一下,broadlink插件升级到0.11.0了,应该已经解决了问题,报错不能下载等网络稳定下来或者用其他方式能下载到最新文件,最近github有点抽,。。。
扔到custom_components里去应急,0.11.0版的
broadlink.zip (9.51 KB, 下载次数: 25)
流水无味
灌水之王
发表于 2019-6-1 09:51:24 | 显示全部楼层
我都找个备用机 乱升级 没问题才升级主的
 楼主| 发表于 2019-6-1 21:21:17 | 显示全部楼层
zorankeinfo 发表于 2019-6-1 01:43
退回去,官方broadlink插件升级到0.10.0,系统没跟上,自定义的插件还在0.9.0还是正常的,等第三版更新应该 ...
老大  我用这个射频的灯能控制 但是开关插座不行。。。。
发表于 2019-6-2 19:15:13 | 显示全部楼层
3楼说的方法可行
发表于 2019-6-5 08:49:43 | 显示全部楼层
遇到同样的问题,按照3楼已经搞定~~
 楼主| 发表于 2019-6-5 10:23:26 | 显示全部楼层
SkyNet 发表于 2019-6-5 08:49
遇到同样的问题,按照3楼已经搞定~~
我也用了2楼老大的方法,可是我的MP1 会报错
GMT+8, 2026-1-1 17:58 , Processed in 0.383330 second(s), 10 queries , MemCached On.
