查看: 11712|回复: 15
[技术探讨] 悟空M1用拦截DNS接入HA后无数据,请大神帮忙看看。
发表于 2019-5-30 21:06:24 | 显示全部楼层 |阅读模式
配置文件:package/phicomm_m1_sensor.yaml
  - platform: phicomm_m1_sensor
  - platform: template
    sensors:
      m1_pm25:
        friendly_name: 空气质量
        value_template: "{{ states.sensor.m1.attributes.pm25 }}"
        unit_of_measurement: μg/m³
      m1_hcho:
        friendly_name: 甲醛
        value_template: "{{ states.sensor.m1.attributes.hcho }}"
        unit_of_measurement: mg/m³
      m1_temperature:
        friendly_name: 温度
        value_template: "{{ states.sensor.m1.attributes.temperature }}"
        unit_of_measurement: °C
      m1_humidity:
        friendly_name: 湿度
        value_template: "{{ states.sensor.m1.attributes.humidity }}"
        unit_of_measurement: "%"
input_number:
  phicomm_m1_led:
    icon: mdi:led-on
    initial: 25
    min: 0
    max: 50
    step: 25
group:
 M1:
    view: no
    entities:
      - sensor.m1_temperature
      - sensor.m1_humidity
      - sensor.m1_pm25
      - sensor.m1_hcho
      - input_number.phicomm_m1_led
homeassistant:
  customize:
    sensor.m1_humidity:
      icon: mdi:water-percent
    sensor.m1_pm25:
      icon: mdi:blur
    sensor.m1_hcho:
      icon: mdi:chemical-weapon
custom_components\phicomm_m1_sensor.py
Support for Phicomm Air Detector M1 plant sensor.
Developer by lixinb
192.168.2.137 aircat.phicomm.com
import logging
import datetime
import json
import re
import select
import voluptuous as vol
from socket import socket, AF_INET, SOCK_STREAM
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.helpers.entity import Entity
import homeassistant.helpers.config_validation as cv
from homeassistant.const import (
    CONF_NAME)
_LOGGER = logging.getLogger(__name__)
SCAN_INTERVAL = datetime.timedelta(seconds=5)
DEFAULT_NAME = 'Phicomm M1'
ATTR_TEMPERATURE = 'temperature'
ATTR_HUMIDITY = 'humidity'
ATTR_PM25 = 'pm25'
ATTR_HCHO = 'hcho'
ATTR_BRIGHTNESS = 'brightness'
CONNECTION_LIST = []
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Set up the Phicomm M1 sensor."""
    _LOGGER.info("PhicommM1Sensor setup_platform")
    name = config.get(CONF_NAME)
    connection_list = CONNECTION_LIST
    sock = socket(AF_INET, SOCK_STREAM)
    sock.settimeout(1)
    try:
        sock.bind(("0.0.0.0", 9000))
        sock.listen(5)
    except OSError as e:
        _LOGGER.warning("PhicommM1Sensor server got %s", e)
        pass
    connection_list.append(sock)
    _LOGGER.warning("PhicommM1Sensor server started on port 9000")
    devs = []
    devs.append(PhicommM1Sensor(
        hass, connection_list, sock, name))
    add_devices(devs)
class PhicommM1Sensor(Entity):
    """Implementing the Phicomm M1 sensor."""
    def __init__(self, hass, connection_list, sock, name):
        """Initialize the sensor."""
        _LOGGER.info("PhicommM1Sensor __init__")
        self.iCount = 0
        self.iClientEmptyLogCount = 0
        self._hass = hass
        self._connection_list = connection_list
        self.sock = sock
        self._name = name
        self._state = None
        self.data = []
        self._state_attrs = {
            ATTR_PM25: None,
            ATTR_TEMPERATURE: None,
            ATTR_HUMIDITY: None,
            ATTR_HCHO: None,
            ATTR_BRIGHTNESS: 50.0,
        self.update()
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def state(self):
        """Return the state of the sensor."""
        return self._state_attrs[ATTR_PM25]
    @property
    def state_attributes(self):
    def shutdown(self, event):
        """Signal shutdown of sock."""
        _LOGGER.debug("Sock close")
        self.sock.shutdown(2)
        self.sock.close()
    def broadcast_data(self, sock, message):
        for socket in self._connection_list:
            if socket != self.sock and socket != sock:
                try:
                    socket.sendall(message)
                except OSError:
                    socket.close()
                    self._connection_list.remove(socket)
    def update(self):
        Update current conditions.
        self.iCount += 1
        heart_msg = b'\xaaO\x01%F\x119\x8f\x0b\x00\x00\x00\x00\x00\x00\x00\x00\xb0\xf8\x93\x11dR\x007\x00\x00\x02{"type":5,"status":1}\xff#END#'
        if self.iCount >= 8:
            for sockA in self._connection_list:
                if sockA is self.sock:
                    continue
                else:
                    try:
                        sockA.sendall(heart_msg)
                        self.iCount = 0
                        _LOGGER.info(
                            'PhicommM1Sensor Force send a heartbeat to %s', sockA.getpeername())
                        break
                        _LOGGER.warning(
                            "PhicommM1Sensor Force send a heartbeat got %s. Closing socket", e)
                        try:
                            sockA.shutdown(2)
                            sockA.close()
                        except OSError:
                            pass
                        self._connection_list.remove(sockA)
                        continue
        read_sockets, write_sockets, error_sockets = select.select(
            self._connection_list, [], [], 0)
        if len(self._connection_list) is 1:
            self.iClientEmptyLogCount += 1
            if self.iClientEmptyLogCount is 13:
                _LOGGER.warning("PhicommM1Sensor Client list is empty")
                return None
        else:
        brightness_state = 50.0
        brightness = self._hass.states.get('input_number.phicomm_m1_led')
        if brightness is not None:
            brightness_state = brightness.state
        if self._state_attrs[ATTR_BRIGHTNESS] != brightness_state:
            send_msg = b'\xaaO\x01\xf2E\x119\x8f\x0b\x00\x00\x00\x00\x00\x00\x00\x00\xb0\xf8\x93\x11T/\x007\x00\x00\x02{"brightness":"%b","type":2}\xff#END#' % str(
                round(float(brightness_state))).encode('utf8')
        else:
            send_msg = None
        for sock in read_sockets:
            if sock is self.sock:
                _LOGGER.warning(
                    "PhicommM1Sensor going to accept new connection")
                try:
                    sockfd, addr = self.sock.accept()
                    sockfd.settimeout(1)
                    self._connection_list.append(sockfd)
                    _LOGGER.warning(
                        "PhicommM1Sensor Client (%s, %s) connected" % addr)
                    try:
                        sockfd.sendall(heart_msg)
                        _LOGGER.warning(
                            "PhicommM1Sensor Force send a heartbeat:%s", heart_msg)
                        _LOGGER.warning("PhicommM1Sensor Client error %s", e)
                        sock.shutdown(2)
                        sock.close()
                        self._connection_list.remove(sockfd)
                        continue
                except OSError:
                    _LOGGER.warning("PhicommM1Sensor Client accept failed")
                    continue
            else:
                data = None
                try:
                    _LOGGER.debug(
                        "PhicommM1Sensor Processing Client %s", sock.getpeername())
                    data = sock.recv(1024)
                    _LOGGER.warning(
                        "PhicommM1Sensor Processing Client error %s", e)
                    continue
                if send_msg is not None:
                    try:
                        sock.sendall(send_msg)
                        sock.shutdown(2)
                        sock.close()
                        self._connection_list.remove(sock)
                        continue
                if data:
                    jsonData = self.parseJsonData(data)
                    if jsonData is not None:
                            ATTR_PM25: jsonData['value'],
                            ATTR_TEMPERATURE: format(float(jsonData['temperature']), '.1f'),
                            ATTR_HUMIDITY: format(float(jsonData['humidity']), '.1f'),
                            ATTR_HCHO: format(float(jsonData['hcho']) / 1000, '.2f'),
                            ATTR_BRIGHTNESS: brightness_state,
                else:
                    _LOGGER.warning("PhicommM1Sensor Client offline, closing")
                    sock.shutdown(2)
                    sock.close()
                    continue
    def parseJsonData(self, data):
        pattern = r"(\{.*?\})"
        jsonStr = re.findall(pattern, str(data), re.M)
        l = len(jsonStr)
        if l > 0:
            return json.loads(jsonStr[l - 1])
        else:
            return None
HA LOGS:显示已经连接又有错误。
PhicommM1Sensor Force send a heartbeat got [Errno 104] Connection reset by peer. Closing socket
下午9:02 custom_components/phicomm_m1_sensor/sensor.py (WARNING) - message first occured at 下午7:53 and shows up 8 times
PhicommM1Sensor Processing Client error [Errno 107] Socket not connected
下午9:01 custom_components/phicomm_m1_sensor/sensor.py (WARNING) - message first occured at 下午7:53 and shows up 25 times
PhicommM1Sensor Force send a heartbeat:b'\xaaO\x01%F\x119\x8f\x0b\x00\x00\x00\x00\x00\x00\x00\x00\xb0\xf8\x93\x11dR\x007\x00\x00\x02{"type":5,"status":1}\xff#END#'
下午9:00 custom_components/phicomm_m1_sensor/sensor.py (WARNING) - message first occured at 下午7:43 and shows up 9 times
PhicommM1Sensor Client (10.0.0.60, 43227) connected
PhicommM1Sensor Client (10.0.0.60, 60072) connected
下午8:50 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
Got unexpected response: None
下午8:43 components/updater/__init__.py (ERROR)
PhicommM1Sensor Client (10.0.0.60, 62676) connected
下午8:41 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
PhicommM1Sensor Client (10.0.0.60, 32759) connected
下午8:31 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
PhicommM1Sensor Client (10.0.0.60, 32656) connected
下午8:22 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
PhicommM1Sensor Client (10.0.0.60, 51887) connected
下午8:12 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
PhicommM1Sensor Client (10.0.0.60, 60169) connected
下午8:03 custom_components/phicomm_m1_sensor/sensor.py (WARNING)
发表于 2019-5-30 23:55:16 | 显示全部楼层
92以上的版本目录结构应该是custom_components/phicomm_m1_sensor/sensor.py
phicomm_m1_sensor   |
                                     |-   __init__.py
                                     |-   manifest.json
                                     |-   sensor.py
你看看会不会可能是这个原因。
 楼主| 发表于 2019-5-31 00:04:22 | 显示全部楼层
phicomm_m1_sensor   |
这几个文件都有,还是多谢老哥回答
发表于 2019-5-31 10:05:36 | 显示全部楼层
M1重启试试 ,我的hassio升级到最新就是这个情况,重启m1就显示了
 楼主| 发表于 2019-5-31 12:52:04 | 显示全部楼层
怎么重启,把电源吗?我重启了很多边了,都不行
发表于 2019-5-31 20:29:15 | 显示全部楼层
先ping 一下aircat看看对不对。
发表于 2019-6-4 19:43:39 | 显示全部楼层
你这位置明显是错了的~~
 楼主| 发表于 2019-6-4 20:48:12 | 显示全部楼层
oosee 发表于 2019-6-4 19:43
你这位置明显是错了的~~
刷了猪大的固件了,一劳永逸!哈!
发表于 2019-6-19 17:31:50 | 显示全部楼层
弄好了吗? 我跟你的一样
发表于 2019-6-19 19:36:59 | 显示全部楼层
添加9000端口没有
GMT+8, 2025-12-30 12:19 , Processed in 1.838462 second(s), 14 queries , MemCached On.
