查看: 13066|回复: 14
[求助] 有大神可以提供一下小米空气净化器2的yaml文件吗
发表于 2019-5-26 23:12:18 | 显示全部楼层 |阅读模式
如题
就是放在packages文件夹里面的,文件名一般是xiaomi_air_purifier.yaml
谢谢
发表于 2019-5-27 07:24:19 | 显示全部楼层
不需要package啊,就几行
fan:
  - platform: xiaomi_miio
    host: 192.168.2.151
    token: xxxxx
 楼主| 发表于 2019-5-27 11:52:17 | 显示全部楼层
natic 发表于 2019-5-27 07:24
不需要package啊,就几行
fan:
不是说这种情况下只有风扇模式?
发表于 2019-5-27 12:14:38 | 显示全部楼层
ivanxxxx 发表于 2019-5-27 11:52
不是说这种情况下只有风扇模式?
这玩意不就是个风扇嘛
 楼主| 发表于 2019-5-27 13:38:34 | 显示全部楼层
主要是我看人家用那个package模式的还可以控制儿童锁,灯光什么的
发表于 2019-5-27 14:24:18 | 显示全部楼层
fan:
  - platform: xiaomi_airpurifier
    host: 192.168.**
    token: ********
  - platform: template
    sensors:
      zhuwomiap_aqi:
        friendly_name: 主卧空气质量
        value_template: "{{ states.fan.zhuwomiap.attributes.aqi }}"
        unit_of_measurement: AQI
      zhuwomiap_temp:
        friendly_name: 主卧温度
        value_template: "{{ states.fan.zhuwomiap.attributes.temperature }}"
        unit_of_measurement: °C
      zhuwomiap_humid:
        friendly_name: 主卧湿度
        value_template: "{{ states.fan.zhuwomiap.attributes.humidity }}"
        unit_of_measurement: "%"
      zhuwomiap_used:
        friendly_name: 滤芯用量
        value_template: "{{ states.fan.zhuwomiap.attributes.filter_hours_used }}"
        unit_of_measurement: '小时'
      zhuwomiap_life:
        friendly_name: 滤芯剩余
        value_template: "{{ states.fan.zhuwomiap.attributes.filter_life_remaining }}"
        unit_of_measurement: '%'
switch:
    switches:
      zhuwomiap_buzzer:
        value_template: "{{ is_state_attr('fan.zhuwomiap', 'buzzer', true) }}"
        turn_on:
          service: airpurifier.set_buzzer_on
          entity_id: fan.zhuwomiap
        turn_off:
          service: airpurifier.set_buzzer_off
input_select:
  zhuwomiap_mode:
    icon: mdi:fan
    options:
      - "自动"
      - "睡眠"
      - "最爱"
      - "待机"
  zhuwomiap_led:
    icon: mdi:led-on
    options:
      - "亮光"
      - "微光"
      - "关闭"
automation:
  - alias: zhuwomiap_get_mode
    initial_state: true
    trigger:
      platform: time_pattern
      seconds: /5
    action:
      service: input_select.select_option
      data_template:
        entity_id: input_select.zhuwomiap_mode
        option: >
          {% if states.fan.zhuwomiap.attributes.mode == "auto" %}自动
          {% elif states.fan.zhuwomiap.attributes.mode == "silent" %}睡眠
          {% elif states.fan.zhuwomiap.attributes.mode == "favorite" %}最爱
          {% elif states.fan.zhuwomiap.attributes.mode == "idle" %}待机
          {% endif %}
  - alias: zhuwomiap_set_mode
    initial_state: true
    trigger:
      platform: state
    action:
      service: fan.turn_on
      data_template:
        speed: >
          {% if states.input_select.zhuwomiap_mode.state == "自动" %}Auto
          {% elif states.input_select.zhuwomiap_mode.state == "睡眠" %}Silent
          {% elif states.input_select.zhuwomiap_mode.state == "最爱" %}Favorite
          {% elif states.input_select.zhuwomiap_mode.state == "待机" %}Idle
          {% endif %}
  - alias: zhuwomiap_get_led
    initial_state: true
    trigger:
      seconds: /5
    action:
      data_template:
        entity_id: input_select.zhuwomiap_led
        option: >
          {% if states.fan.zhuwomiap.attributes.led_brightness == 0 %}亮光
          {% elif states.fan.zhuwomiap.attributes.led_brightness == 1 %}微光
          {% elif states.fan.zhuwomiap.attributes.led_brightness == 2 %}关闭
          {% endif %}
  - alias: zhuwomiap_set_led
    initial_state: true
    trigger:
      platform: state
    action:
      service: airpurifier.set_led_brightness
      data_template:
        brightness: >
          {% if states.input_select.zhuwomiap_led.state == "亮光" %}0
          {% elif states.input_select.zhuwomiap_led.state == "微光" %}1
          {% elif states.input_select.zhuwomiap_led.state == "关闭" %}2
          {% endif %}
homeassistant:
  customize:
    fan.zhuwomiap:
      friendly_name: 主卧空净
      extra_data_template: 滤芯已用${attributes.filter_hours_used}小时,剩余${attributes.filter_life_remaining}%
    switch.zhuwomiap_buzzer:
      icon: mdi:volume-high
      friendly_name: 提示音
    sensor.zhuwomiap_aqi:
      icon: mdi:blur
      device_class: pm25
    sensor.zhuwomiap_humid:
      icon: mdi:water-percent
      device_class: humidity
 楼主| 发表于 2019-5-27 15:26:47 | 显示全部楼层
缥缈的孤鸿 发表于 2019-5-27 14:24
[code]fan:
谢谢大神
发表于 2019-5-27 16:47:50 | 显示全部楼层
净化器得  token:  获取好麻烦啊
发表于 2019-7-7 23:08:06 | 显示全部楼层
谢谢 手下了
发表于 2019-8-11 13:11:50 | 显示全部楼层
用这个 建一个新的yaml。放在packages里。识别不了,ip token 都对。在configuration里添加成风扇模式是可以的。求指导
GMT+8, 2025-12-23 14:08 , Processed in 1.519774 second(s), 14 queries , MemCached On.
