楼主: jiluxinqing
[插件集成] 网易云音乐【支持语音播放专辑】【2020-7-14更新】
发表于 2020-7-27 16:19:24 | 显示全部楼层
121665460 发表于 2020-7-27 15:06
看了下日志,手机访问没有请求登录的接口。不知道什么原因
继续排查下只要一个浏览器登录过,其它浏览器都无法登录
发表于 2020-8-5 12:40:24 | 显示全部楼层
请求帮助:
Logger: homeassistant.bootstrap
Source: custom_components/ha_cloud_music/media_player.py:29
First occurred: 下午12:34:48 (1 occurrences)
Last logged: 下午12:34:48
Error setting up integration media_player - received exception
  File "/srv/homeassistant/homeassistant_venv/lib/python3.7/site-packages/homeassistant/setup.py", line 68, in async_setup_component
    return await task  # type: ignore
  File "/srv/homeassistant/homeassistant_venv/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component
    hass, config, integration
  File "/srv/homeassistant/homeassistant_venv/lib/python3.7/site-packages/homeassistant/config.py", line 804, in async_process_component_config
    platform = p_integration.get_platform(domain)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.7/site-packages/homeassistant/loader.py", line 322, in get_platform
    f"{self.pkg_path}.{platform_name}"
  File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/home/homeassistant/.homeassistant/custom_components/ha_cloud_music/media_player.py", line 29, in <module>
    from .source_mpd import MediaPlayerMPD
  File "/home/homeassistant/.homeassistant/custom_components/ha_cloud_music/source_mpd.py", line 121
    self.is_tts == False:
SyntaxError: invalid syntax
 楼主| 发表于 2020-8-5 14:49:13 | 显示全部楼层
linlingzi 发表于 2020-8-5 12:40
请求帮助:
Source: custom_components/ha_cloud_music/media_player.py: ...
我的锅,判断没写If
http://github.com/shaonianzhentan
发表于 2020-8-5 16:56:26 | 显示全部楼层
jiluxinqing 发表于 2020-8-5 14:49
我的锅,判断没写If
更新了吗?我用回3.3版本了
发表于 2020-8-5 17:13:11 | 显示全部楼层
我的锅,判断没写If
感谢这么快的回复及修改,现在可以用了,播放器只有VLC和网页播放器可选,不知道是不是我MPD的问题
 楼主| 发表于 2020-8-5 21:40:32 | 显示全部楼层
linlingzi 发表于 2020-8-5 17:13
感谢这么快的回复及修改,现在可以用了,播放器只有VLC和网页播放器可选,不知道是不是我MPD的问题 ...
你没配置mpd_host   ????
发表于 2020-8-5 23:44:26 | 显示全部楼层
jiluxinqing 发表于 2020-8-5 21:40
你没配置mpd_host   ????
这样的啊
media_player:
  - platform: mpd
    host: 127.0.0.1
 楼主| 发表于 2020-8-6 13:58:17 | 显示全部楼层
linlingzi 发表于 2020-8-5 23:44
这样的啊
media_player:
  - platform: mpd
你都不看文档的么?
4.x版本和3.x版本完全就不是一个东西,配置都不一样,使用的时候一定要仔细看文档
media_player:
  - platform: ha_cloud_music
    api_url: 接口请求地址
    mpd_host: MPD播放器host(如果你有的话)
发表于 2020-8-6 19:31:01 | 显示全部楼层
jiluxinqing 发表于 2020-8-6 13:58
你都不看文档的么?
忘了,开始用4.0测试的,后来因为有问题就改3.3了,谢谢提醒
发表于 2020-9-8 14:04:24 | 显示全部楼层
设置用户名,密码登录不成功
GMT+8, 2026-1-14 03:26 , Processed in 0.061425 second(s), 16 queries , MemCached On.
