查看: 12956|回复: 12
[求助] 小白求助解决home-assistant错误
发表于 2019-5-11 16:53:21 | 显示全部楼层 |阅读模式
2019-05-11 08:31:13 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: forecast
Integration not found: name
Integration not found: introduction
Integration not found: monitored_conditions
HA的信息里面一直提及这个错误,修改configuration.yaml还是有错误,不知怎么处理,请大大帮忙出手!
发表于 2019-5-11 16:55:57 | 显示全部楼层
应该是吧configuration.yaml里面的forecast删除掉就行了,还是不行请贴一下配置
 楼主| 发表于 2019-5-11 17:38:09 | 显示全部楼层
感谢回复!还是不行
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 23.0821
  longitude: 113.2710
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 100
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
monitored_conditions:
- symbol
- temperature #气温
- precipitation #雨量
- windSpeed #风速
- pressure #气压
- windDirection #风向
- humidity #湿度
# Text to speech
tts:
  - platform: google_translate
    service_name: google_say
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
发表于 2019-5-11 17:52:05 | 显示全部楼层
himrleo 发表于 2019-5-11 17:38
感谢回复!还是不行
homeassistant:
格式错了,请严格按照yaml格式进行缩进
活跃会员教程狂人
发表于 2019-5-11 18:25:02 | 显示全部楼层
- platform: yr
接楼上大佬,至少这个地方缩进不对。
所有过往,皆为序章。
 楼主| 发表于 2019-5-11 22:07:40 | 显示全部楼层
好的,谢谢大佬!!!
 楼主| 发表于 2019-5-11 22:08:50 | 显示全部楼层
咸味土豆 发表于 2019-5-11 18:25
[code]# Weather prediction
- platform: yr
了解,谢谢大佬!!!
 楼主| 发表于 2019-5-11 22:24:39 | 显示全部楼层
另外大佬,一直有这个错误显示,请问是哪里的问题?求教
2019-05-11 14:19:22 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: introduction
 楼主| 发表于 2019-5-11 22:29:43 | 显示全部楼层
- platform: yr
另外大佬,一直有这个错误显示,请问是哪里的问题?求教 2019-05-11 14:19:22 ERROR (MainThread) [homeassistant.components.hassio] Integration not found: introduction
活跃会员教程狂人
发表于 2019-5-11 22:31:54 | 显示全部楼层
himrleo 发表于 2019-5-11 22:29
另外大佬,一直有这个错误显示,请问是哪里的问题?求教 2019-05-11 14:19:22 ERROR (MainThread) [homea ...
把configuration.yaml里面有一个introduction注释掉就行了。那个官方已经弃用了。
所有过往,皆为序章。
GMT+8, 2025-12-24 03:06 , Processed in 0.429709 second(s), 5 queries , MemCached On.
