楼主: cnk700i
[插件集成] 基于和风天气的lovelace天气卡片【丰富信息】【动态图标】
发表于 2021-9-2 21:59:14 | 显示全部楼层
学习一下
发表于 2021-9-2 22:42:58 | 显示全部楼层
謝謝前輩辛苦分享
发表于 2021-9-3 08:15:03 | 显示全部楼层
66666666666666666666666666666
发表于 2021-9-3 17:30:36 | 显示全部楼层
哈哈哈哈
发表于 2021-9-3 18:15:40 | 显示全部楼层
2021-09-03 10:13:58 ERROR (MainThread) [homeassistant.components.homeassistant] The system cannot restart because the configuration is not valid: Platform error weather.hf_weather - Integration 'hf_weather' not found.
2021-09-03 10:13:58 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [2857597320] The system cannot restart because the configuration is not valid: Platform error weather.hf_weather - Integration 'hf_weather' not found.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1492, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1527, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 728, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 171, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Platform error weather.hf_weather - Integration 'hf_weather' not found.
我重启一直报错
发表于 2021-9-4 18:52:02 | 显示全部楼层
还有这种操作吗,试试看
发表于 2021-9-4 22:58:41 | 显示全部楼层
学习一下~~
发表于 2021-9-5 00:36:00 来自手机 | 显示全部楼层
学习一下
发表于 2021-9-7 11:03:08 | 显示全部楼层
基于和风天气的lovelace天气卡片
lilt 手机认证
发表于 2021-9-7 17:03:10 | 显示全部楼层
学习一下!!!
GMT+8, 2026-1-15 19:08 , Processed in 0.223774 second(s), 11 queries , MemCached On.
