查看: 7441|回复: 2
(已降级解决)求助N1刷armbian装hassio后nodered启动不了
流水无味
灌水之王
发表于 2019-5-1 18:41:46 | 显示全部楼层 |阅读模式
N1刷的armbian5.77然后用的N大的一键安装hassio,(本以为是armbian版本缘故换了3个和刷emmc都一样出错)
hassio侧边栏直接安装node red启动不了版本是3.0.3,ha版本0.92.1
对比下了X86虚拟机安装debian-docker-hassio-node red 就这里开始出错
[18:30:58] INFO: Starting NGinx...
PANIC: unprotected error in call to Lua API (bad light userdata pointer)
大佬们帮忙看看,0.86.2升级0.92.1中
折腾到最后快成功了居然node red装不上
Welcome to Node-RED
1 May 18:30:58 - [info] Server now running at http://127.0.0.1:46836/
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
经过黄溜溜  CXA918   指点已降级2.0.2版本解决
https://bbs.hassbian.com/thread-6852-2-1.html
第11 14 19楼
发表于 2019-5-1 21:13:34 | 显示全部楼层
消灭0回复
参与人数 1金钱 +20 收起 理由
xieahui + 20 每天100 不要钱
发表于 2019-5-7 14:25:55 | 显示全部楼层
我也要降级了,被3.0.3坑死了
GMT+8, 2026-1-1 20:08 , Processed in 0.074014 second(s), 6 queries , MemCached On.
