查看: 8084|回复: 6
[技术探讨] nodemcu 32s刷ESPHOME遇到问题
发表于 2019-4-28 22:48:45 | 显示全部楼层 |阅读模式
为啥我的nodemcu 32s用usb刷不进去,求助
提示:
Retrieving maximum program size .pioenvs/esp32/firmware.elf
Checking size .pioenvs/esp32/firmware.elf
DATA:    [=         ]  12.3% (used 40176 bytes from 327680 bytes)
PROGRAM: [=====     ]  51.8% (used 848106 bytes from 1638400 bytes)
Configuring upload protocol...
AVAILABLE: esp-prog, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Use manually specified: /dev/cu.SLAB_USBtoUART
Uploading .pioenvs/esp32/firmware.bin
esptool.py v2.6
Serial port /dev/cu.SLAB_USBtoUART
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
*** [upload] Error 2
========================== [ERROR] Took 64.18 seconds ========================
发表于 2019-4-29 06:37:01 | 显示全部楼层
偶尔遇到,多刷几次就可以了
发表于 2019-4-29 08:53:24 | 显示全部楼层
Note
If you’re just seeing Connecting....____.... on the screen and the flashing fails, that might be a sign that the ESP is defect or cannot be programmed. Please double check the UART wires are connected correctly if flashing using a USB to UART bridge. For some devices you need to keep pressing the BOOT button until flashing has begun (ie. Geekcreit DOIT ESP32 DEVKIT V1).
发表于 2019-4-29 09:21:26 | 显示全部楼层
看上去是数据线的问题,因为前面的都是正常的,开始刷机才出现连接异常
发表于 2019-4-29 11:52:14 | 显示全部楼层
不稳定,多试试就好了
 楼主| 发表于 2019-5-1 23:06:44 | 显示全部楼层
Mac试了好几回,居然成功了,感觉是Mac旧驱动不大稳定的问题。
发表于 2020-2-22 15:56:14 | 显示全部楼层
感谢大神分享,翰思彼岸有你更精彩
GMT+8, 2025-12-31 15:30 , Processed in 0.341313 second(s), 8 queries , MemCached On.
