查看: 8059|回复: 6
[经验分享] 升级到0.92后插件使用的注意事项
发表于 2019-4-26 09:28:31 | 显示全部楼层 |阅读模式
在xxxx插件目录中增加一个文件manifest.json
  "domain": "my_xxxx",
  "name": "xxxx",
  "documentation": "https://www.example.com",
  "dependencies": [],
  "codeowners": [],
  "requirements": []
waaw 手机认证
发表于 2019-4-26 09:36:03 | 显示全部楼层
没看懂,能不能具体解释下?
发表于 2019-4-26 09:39:29 | 显示全部楼层
waaw 发表于 2019-4-26 09:36
没看懂,能不能具体解释下?
参考我的帖子
https://bbs.hassbian.com/forum.p ... mp;extra=#pid206517
发表于 2019-4-26 09:45:49 | 显示全部楼层
我总是升级不成功,下面是升级过程中出的问题。HA是手工在raspbian中安装的,未使用虚拟环境,有类似情况吗?
https://community.home-assistant ... -4-to-0-92-0/113015
pip3 install --upgrade homeassistant
Looking in indexes: [url=https://pypi.org/simple]https://pypi.org/simple[/url], [url=https://www.piwheels.org/simpleCollecting]https://www.piwheels.org/simpleCollecting[/url] homeassistant
Using cached [url=https://files.pythonhosted.org/p]https://files.pythonhosted.org/p[/url] ... -any.whlRequirement already satisfied, skipping upgrade: aiohttp==3.5.4 in /usr/local/lib/python3.5/dist-packages (from homeassistant) (3.5.4)
Collecting cryptography==2.6.1 (from homeassistant)
Using cached [url=https://files.pythonhosted.org/p]https://files.pythonhosted.org/p[/url] ... graphy-2.6.1.tar.gz
Installing build dependencies ... done
Getting requirements to build wheel ... done
ERROR: Exception:Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/cli/base_command.py", line 178, in main    status = self.run(options, args)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/commands/install.py", line 352, in run    resolver.resolve(requirement_set)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 131, in resolve    self._resolve_one(requirement_set, req)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 294, in _resolve_one    abstract_dist = self._get_abstract_dist_for(req_to_install)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/resolve.py", line 242, in _get_abstract_dist_for    self.require_hashes
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 368, in prepare_linked_requirement    abstract_dist.prep_for_dist(finder, self.build_isolation)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 175, in prep_for_dist    self.install_backend_dependencies(finder=finder)
File "/usr/local/lib/python3.5/dist-packages/pip/_internal/operations/prepare.py", line 123, in install_backend_dependencies    reqs = req.pep517_backend.get_requires_for_build_wheel()
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pep517/wrappers.py", line 71, in get_requires_for_build_wheel    'config_settings': config_settings
File "/usr/local/lib/python3.5/dist-packages/pip/_vendor/pep517/wrappers.py", line 162, in _call_hook    raise BackendUnavailablepip._vendor.pep517.wrappers.BackendUnavailable
发表于 2019-4-26 10:20:28 | 显示全部楼层
昨天升到92,又降回91.4了。。
发表于 2019-4-26 13:49:30 来自手机 | 显示全部楼层
缥缈的孤鸿 发表于 2019-4-26 10:20
昨天升到92,又降回91.4了。。
求降级教程!
发表于 2019-4-26 14:04:03 | 显示全部楼层
我直接docker pull的0.91.4
GMT+8, 2025-11-9 03:18 , Processed in 0.240445 second(s), 6 queries , MemCached On.
