查看: 3338|回复: 3
[求助] 小米的插座和插排连不上会是什么原因?
发表于 2019-4-25 21:30:15 | 显示全部楼层 |阅读模式
小米的插座和插排连不上会是什么原因?token已经拿到
switch:
  - platform: xiaomi_miio
    host: 我的ip
    token: 保密
    host: 我的ip
    token: 不写出来了
发表于 2019-4-25 21:34:24 | 显示全部楼层
看下日志报错是什么,一般来说是token有问题
 楼主| 发表于 2019-4-25 21:50:24 | 显示全部楼层
2019-04-25 13:34:13 INFO (MainThread) [homeassistant.components.xiaomi_miio.switch] Initializing with host 192.168.4.2 (token 39b80...)
2019-04-25 13:34:13 INFO (MainThread) [homeassistant.components.xiaomi_miio.switch] Initializing with host 192.168.4.9 (token 5b903...)
2019-04-25 13:34:14 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform xiaomi_miio
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/volume1/NAS/opt/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
    return fut.result()
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/homeassistant/components/xiaomi_miio/switch.py", line 119, in async_setup_platform
    device_info = miio_device.info()
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/miio/device.py", line 329, in info
    return DeviceInfo(self.send("miIO.info"))
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/miio/device.py", line 243, in send
    m = Message.build(msg, token=self.token)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 352, in build
    self.build_stream(obj, stream, **contextkw)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 364, in build_stream
    self._build(obj, stream, context, "(building)")
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 2003, in _build
    buildret = sc._build(subobj, stream, context, path)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 2472, in _build
    return self.subcon._build(obj, stream, context, path)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 4078, in _build
    buildret = self.subcon._build(obj, stream, context, path)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 4365, in _build
    buildret = self.subcon._build(value, stream, context, path)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/construct/core.py", line 718, in _build
    obj2 = self._encode(obj, context, path)
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/miio/protocol.py", line 144, in _encode
    context['_']['token'])
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/miio/protocol.py", line 71, in encrypt
    backend=default_backend())
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/cryptography/hazmat/backends/__init__.py", line 15, in default_backend
    from cryptography.hazmat.backends.openssl.backend import backend
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/__init__.py", line 7, in <module>
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 65, in <module>
    from cryptography.hazmat.bindings.openssl import binding
  File "/volume1/NAS/opt/local/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module>
    from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /volume1/NAS/opt/local/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so: undefined symbol: pthread_atfork
    return fut.result()
发表于 2020-1-29 19:34:48 | 显示全部楼层
遇到类似的错误,请大神解救
ImportError: /opt/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so: undefined symbol: ENGINE_get_name
  File "/opt/bin/mirobo", line 8, in <module>
    sys.exit(cli())
  File "/opt/lib/python3.7/site-packages/miio/click_common.py", line 59, in __call__
    return self.main(*args, **kwargs)
  File "/opt/lib/python3.7/site-packages/click/core.py", line 717, in main
    rv = self.invoke(ctx)
  File "/opt/lib/python3.7/site-packages/click/core.py", line 1137, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/opt/lib/python3.7/site-packages/click/core.py", line 956, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/opt/lib/python3.7/site-packages/click/core.py", line 555, in invoke
    return callback(*args, **kwargs)
  File "/opt/lib/python3.7/site-packages/click/decorators.py", line 64, in new_func
    return ctx.invoke(f, obj, *args, **kwargs)
  File "/opt/lib/python3.7/site-packages/miio/vacuum_cli.py", line 415, in info
    res = vac.info()
  File "/opt/lib/python3.7/site-packages/miio/device.py", line 352, in info
  File "/opt/lib/python3.7/site-packages/miio/device.py", line 253, in send
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 336, in build
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 348, in build_stream
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 2000, in _build
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 2438, in _build
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 3991, in _build
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 4278, in _build
  File "/opt/lib/python3.7/site-packages/construct/core.py", line 701, in _build
  File "/opt/lib/python3.7/site-packages/miio/protocol.py", line 156, in _encode
    json.dumps(obj).encode("utf-8") + b"\x00", context["_"]["token"]
  File "/opt/lib/python3.7/site-packages/miio/protocol.py", line 82, in encrypt
    cipher = Cipher(algorithms.AES(key), modes.CBC(iv), backend=default_backend())
  File "/opt/lib/python3.7/site-packages/cryptography/hazmat/backends/__init__.py", line 15, in default_backend
  File "/opt/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/__init__.py", line 7, in <module>
  File "/opt/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 75, in <module>
  File "/opt/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
GMT+8, 2025-12-23 16:49 , Processed in 0.054767 second(s), 17 queries , MemCached On.
