查看: 7097|回复: 2
[技术探讨] 求助!ha中怎么添加RGB全彩LED的颜色控制card
发表于 2019-4-23 14:33:41 | 显示全部楼层 |阅读模式
我按照官方教程修改了configuration.yaml,添加了一下内容:
- platform: mqtt
    name: "Light RGB test"
    state_topic: "office/rgb1/light/status"
    command_topic: "office/rgb1/light/switch"
    brightness_state_topic: "office/rgb1/brightness/status"
    brightness_command_topic: "office/rgb1/brightness/set"
    rgb_state_topic: "office/rgb1/rgb/status"
    rgb_command_topic: "office/rgb1/rgb/set"
    state_value_template: "{{ value_json.state }}"
    brightness_value_template: "{{ value_json.brightness }}"
    rgb_value_template: "{{ value_json.rgb | join(',') }}"
    qos: 0
    payload_on: "ON"
    payload_off: "OFF"
    optimistic: false
但是添加了light卡片过后,始终看不到那个可以选颜色的卡片,有高手知道应该怎么设置吗?请指点一下。
发表于 2019-4-23 14:46:47 | 显示全部楼层
先看下日志有没有报错
发表于 2019-4-23 15:06:52 | 显示全部楼层
你用的什么固件? tasmota可以让homeassistant discovery的。 或者esphome也帮你自动连上HA,都不用再配置了
GMT+8, 2025-8-18 23:56 , Processed in 0.087259 second(s), 14 queries , MemCached On.
