查看: 6484|回复: 4
[已解决] esphome设备已连接并且可控,日志提示连接失败
发表于 2019-4-19 11:46:31 | 显示全部楼层 |阅读模式
esphome都已经配置完了,状态是online,在集成里面也配置了,也可以通过homeassistant进行控制esphome设备,但是看日志的时候,却提示连接失败,请大神指点下是哪错了,还是少配置了?
INFO Reading configuration...INFO Starting log output from livingroom.local using esphome APIINFO Connecting to livingroom.local:6053 (0.0.0.0)WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 1 secondsINFO Connecting to livingroom.local:6053 (0.0.0.0)WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 2 secondsINFO Connecting to livingroom.local:6053 (0.0.0.0)WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 4 secondsINFO Connecting to livingroom.local:6053 (0.0.0.0)WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 0.0.0.0: [Errno 111] Connection refused). Re-Trying in 8 seconds
已解决,按照大神们的指导,添加ip,问题就解决了,感谢
wifi:
  ssid: MyHomeNetwork
  password: VerySafePassword
  # Optional manual IP
  manual_ip:
    static_ip: 10.0.0.42
    gateway: 10.0.0.1
    subnet: 255.255.255.0
发表于 2019-4-19 12:11:11 | 显示全部楼层
家里的dns配置不对,你的工具没有找到esphome的地址。
发表于 2019-4-19 12:19:44 | 显示全部楼层
可以在配置中增加ip地址,试试看
wifi:
  ssid: MyHomeNetwork
  manual_ip:
    gateway: 10.0.0.1
 楼主| 发表于 2019-4-19 13:39:19 | 显示全部楼层
感觉不像是dns的问题,因为homeassistant已经可以控制了
 楼主| 发表于 2019-4-19 13:40:27 | 显示全部楼层
xuyang 发表于 2019-4-19 12:19
可以在配置中增加ip地址,试试看
wifi:
  ssid: MyHomeNetwork
谢谢了,我稍后试试
GMT+8, 2025-11-7 10:11 , Processed in 1.064802 second(s), 7 queries , MemCached On.
