楼主: natic
[基础教程] ESPHome刷机教程
发表于 2019-8-10 12:26:23 | 显示全部楼层
感谢分享!~~~~
发表于 2019-8-10 16:06:29 | 显示全部楼层
刷上固件了,识别到了
发表于 2019-8-11 11:18:54 | 显示全部楼层
学习学习学习学习
gzh
发表于 2019-8-11 20:50:38 来自手机 | 显示全部楼层
谢谢分享
发表于 2019-8-14 17:54:32 来自手机 | 显示全部楼层
回家试试。
发表于 2019-8-26 02:27:08 | 显示全部楼层
驱动也装好了,不知道为什么右上角还是只有ota上传
 楼主| 发表于 2019-8-26 07:15:51 | 显示全部楼层
docker版本的嘛?
发表于 2019-8-26 09:05:03 | 显示全部楼层
natic 发表于 2019-8-26 07:15
docker版本的嘛?
是啊是啊
 楼主| 发表于 2019-8-26 09:12:45 | 显示全部楼层
docker版本需要把设备从宿主机映射到容器,hassio版本建议先在电脑上面刷机,然后吧yaml拷贝到hassio进行后续OTA
发表于 2019-8-26 09:30:42 | 显示全部楼层
  File "/usr/local/bin/esphome", line 6, in <module>
    from esphome.__main__ import main
  File "/usr/local/lib/python2.7/dist-packages/esphome/__main__.py", line 10, in <module>
    from esphome import const, writer, yaml_util
  File "/usr/local/lib/python2.7/dist-packages/esphome/writer.py", line 7, in <module>
    from esphome.config import iter_components
  File "/usr/local/lib/python2.7/dist-packages/esphome/config.py", line 15, in <module>
    from esphome import core, core_config, yaml_util
  File "/usr/local/lib/python2.7/dist-packages/esphome/core_config.py", line 6, in <module>
    import esphome.config_validation as cv
  File "/usr/local/lib/python2.7/dist-packages/esphome/config_validation.py", line 1242, in <module>
    Optional(CONF_COMMAND_TOPIC): All(requires_component('mqtt'), subscribe_topic),
  File "/usr/local/lib/python2.7/dist-packages/esphome/voluptuous_schema.py", line 198, in extend
    ret = super(_Schema, self).extend(schema, extra=extra)
  File "/usr/local/lib/python2.7/dist-packages/voluptuous/schema_builder.py", line 782, in extend
    return result_cls(result, required=result_required, extra=result_extra)
TypeError: __init__() got an unexpected keyword argument 'required'
root@raspberrypi:~# esphome config  /dashboard
root@raspberrypi:~# esphome config dashboard
谢谢解答,但是我在命令行装,执行到浏览器配置这一步就报错了
GMT+8, 2026-1-16 09:25 , Processed in 1.666147 second(s), 7 queries , MemCached On.
