楼主: qgy18
[经验分享] 造梦者Dream-maker新风机接入HA经验分享
发表于 2020-11-21 23:31:29 | 显示全部楼层
抓包搞定了,已经把我的新风机信息都抓出来了。关键是package该怎么写
发表于 2021-3-9 11:23:20 | 显示全部楼层
也学习一下,是不是代码已经是可以直接使用了
发表于 2021-3-11 10:39:20 | 显示全部楼层
小白问问题:
fan:
  - platform: dream_maker
  - platform: template
    sensors:
      dream_maker_fresh_air_system_temperature:
        value_template: '{{ states.fan.dream_maker_fresh_air_system.attributes["temperature"]|round(2) }}'
        device_class: temperature
        unit_of_measurement: '°C'
      dream_maker_fresh_air_system_co2:
        value_template: '{{ states.fan.dream_maker_fresh_air_system.attributes["co2"] }}'
        unit_of_measurement: 'ppm'
      dream_maker_fresh_air_system_rh:
        value_template: '{{ states.fan.dream_maker_fresh_air_system.attributes["humidity"]|round(2) }}'
        device_class: humidity
        unit_of_measurement: '%'
      dream_maker_fresh_air_system_pm25:
        value_template: '{{ states.fan.dream_maker_fresh_air_system.attributes["aqi"] }}'
        unit_of_measurement: 'μg/m³'
      dream_maker_fresh_air_system_pm25_out:
        value_template: '{{ states.fan.dream_maker_fresh_air_system.attributes["aqi_out"] }}'
input_select:
  dream_maker_set_speed:
    icon: mdi:fan
    options:
      - "关闭"
      - "小"
      - "中"
      - "大"
      - "全速"
automation:
  - alias: dream_maker_get_speed
    initial_state: true
    trigger:
      platform: time_pattern
      seconds: /5
    action:
      service: input_select.select_option
      data_template:
        entity_id: input_select.dream_maker_set_speed
        option: >
          {% if states.fan.dream_maker_fresh_air_system.attributes.speed == "off" %}关闭
          {% elif states.fan.dream_maker_fresh_air_system.attributes.speed == "low" %}小
          {% elif states.fan.dream_maker_fresh_air_system.attributes.speed == "medium" %}中
          {% elif states.fan.dream_maker_fresh_air_system.attributes.speed == "high" %}大
          {% elif states.fan.dream_maker_fresh_air_system.attributes.speed == "max" %}全速
          {% endif %}
  - alias: dream_maker_set_speed
    initial_state: true
    trigger:
      platform: state
    action:
      service: fan.set_speed
      data_template:
        entity_id: fan.dream_maker_fresh_air_system
        speed: >
          {% if states.input_select.dream_maker_set_speed.state == "关闭" %}off
          {% elif states.input_select.dream_maker_set_speed.state == "小" %}low
          {% elif states.input_select.dream_maker_set_speed.state == "中" %}medium
          {% elif states.input_select.dream_maker_set_speed.state == "大" %}high
          {% elif states.input_select.dream_maker_set_speed.state == "全速" %}max
          {% endif %}
homeassistant:
  customize:
    sensor.dream_maker_fresh_air_system_co2:
      friendly_name: CO₂
    sensor.dream_maker_fresh_air_system_pm25:
      icon: mdi:blur
      friendly_name: PM2.5
    sensor.dream_maker_fresh_air_system_pm25_out:
      icon: mdi:blur
      friendly_name: PM2.5_Outdoor
    sensor.dream_maker_fresh_air_system_temperature:
      friendly_name: Temperature
    sensor.dream_maker_fresh_air_system_rh:
      friendly_name: Humidity
    fan.dream_maker_fresh_air_system:
      friendly_name: '新风机'
这段应该是放到configuration中里面吗?
发表于 2021-3-12 13:07:28 | 显示全部楼层
不行估计我得从基础学起
发表于 2021-8-3 11:54:34 | 显示全部楼层
这样的贴,小白们很需要啊。我有个小区中央空调的APP也想接入到ha
发表于 2021-11-9 11:18:15 | 显示全部楼层
太需要这个,我家里有3台,求大佬放完整的安装
发表于 2022-2-28 15:46:37 | 显示全部楼层
大神能提供完整的吗 ,家里有2台造梦者新风机,非常感谢
发表于 2023-6-1 12:31:01 | 显示全部楼层
请问大佬,现在造梦者还能接进HA吗? 我想买他们那个空气检测来接入呢
发表于 2023-6-1 16:55:48 | 显示全部楼层
我也有个造梦者的电风扇,现在是通过呼叫小爱音箱的服务来实现控制的,
希望能够就是抓包直接接入HA
发表于 2024-9-14 22:16:37 | 显示全部楼层
看来要抓包获取APP_KEY之类的参数,mark下回头试试
GMT+8, 2026-1-14 21:08 , Processed in 1.684018 second(s), 11 queries , MemCached On.
