查看: 7368|回复: 0
[已解决] Portainer无法打开,求助
发表于 2019-4-15 17:03:39 | 显示全部楼层 |阅读模式
有大神相助,已解决。
N1装的ARMDIAN,一键脚本安装的HASSIO。
0.91.3版本,今天手贱把NODE-RED升级到3.0,不能运行,很不爽,
于是就重刷了系统,
清洁溜溜的系统第一个安装portainer以便nodered2.0.2拉回来后方便挂载。
可就这东西也是运行不起来,不知道怎么处理,求助各位大神,谢谢了。
19-04-15 08:49:09 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-04-15 08:49:20 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json:
19-04-15 08:56:59 WARNING (SyncWorker_2) [hassio.docker.addon] Portainer run with disabled protected mode!
19-04-15 08:56:59 INFO (SyncWorker_2) [hassio.docker.interface] Clean addon_a0d7b954_portainer application
19-04-15 08:57:00 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on hassioaddons/portainer-aarch64 with version v0.6.0
19-04-15 08:57:02 ERROR (MainThread) [hassio.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:1337 ssl:None [Connection refused]
19-04-15 08:57:06 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_portainer
GMT+8, 2025-12-24 07:05 , Processed in 0.118637 second(s), 7 queries , MemCached On.
