查看: 3158|回复: 2
[求助] 求助高手homeassistant安装原生HomeKit 报错
发表于 2019-4-15 00:42:44 | 显示全部楼层 |阅读模式
2019-04-15 00:37:05 ERROR (MainThread) [homeassistant.setup] Error during setup of component homekit
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/setup.py", line 151, in _async_setup_component
    hass, processed_config)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/__init__.py", line 80, in async_setup
    await hass.async_add_executor_job(homekit.setup)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/__init__.py", line 214, in setup
    from .accessories import HomeBridge, HomeDriver
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/homekit/accessories.py", line 8, in <module>
    from pyhap.accessory_driver import AccessoryDriver
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/pyhap/accessory_driver.py", line 46, in <module>
    from pyhap.hap_server import HAPServer
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/pyhap/hap_server.py", line 20, in <module>
    from Crypto.Protocol.KDF import HKDF
ImportError: cannot import name 'HKDF'
发表于 2019-4-15 09:23:40 | 显示全部楼层
homekit:
就这7个字母+1个冒号试试?
还是docker好用,不用关心环境支持问题
发表于 2019-4-15 10:02:23 | 显示全部楼层
我用的内置的,比较省心
GMT+8, 2025-12-24 05:08 , Processed in 1.220260 second(s), 4 queries , MemCached On.
