查看: 21577|回复: 14
[流程系列] 自动备份配置文件流程(git)
发表于 2019-4-14 21:47:52 | 显示全部楼层 |阅读模式
----前置技能-----
使用git (推荐gitee,秒push,github太卡)
流程如图
本来想用watch节点判断文件变化,但是有问题. 不知道是我不会用还是有bug, 更新到最新版本0.20.5也不行.
[{"id":"5e97313b.f9091","type":"exec","z":"524b16d7.a8bfe8","command":"cd ~/.node-red;git add .;git commit -m 'auto commit';git push","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"提交git","x":810,"y":580,"wires":[[],["9f6a62f2.ce3a9"],[]]},{"id":"9f6a62f2.ce3a9","type":"debug","z":"524b16d7.a8bfe8","name":"记录日志","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":960,"y":580,"wires":[]},{"id":"18d99690.1adbf9","type":"exec","z":"524b16d7.a8bfe8","command":"ls -l ~/.node-red/flows_yinzhennan-ubuntu.json","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"文件时间戳","x":390,"y":580,"wires":[["30975ef7.e67512"],[],[]]},{"id":"dd33899f.802088","type":"inject","z":"524b16d7.a8bfe8","name":"10秒一次","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":580,"wires":[["18d99690.1adbf9"]]},{"id":"30975ef7.e67512","type":"function","z":"524b16d7.a8bfe8","name":"判断变化","func":"if(context.flow.get('justChanged')==msg.payload){\n    msg.payload = 1;\n    return msg;\n}\n\ncontext.flow.set('justChanged',msg.payload);\nmsg.payload = 2;\nreturn msg;\n","outputs":1,"noerr":0,"x":540,"y":580,"wires":[["b3c7c598.4d30d8"]]},{"id":"b3c7c598.4d30d8","type":"switch","z":"524b16d7.a8bfe8","name":"修改过","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":680,"y":580,"wires":[["5e97313b.f9091"]]}]
另外请配合我的.gitignore食用
/nodes
/node_modules
/lib
/deps
*.bak
*.backup
*.log
*.db
__pycache__/
再也不怕改错流程了
同理也可以自动备份homeassistant或其他服务的配置文件.
参与人数 2金钱 +40 收起 理由
neroxps + 20 感谢楼主分享!
+ 20 纳尼,还有这种操作?
发表于 2019-4-14 22:48:12 | 显示全部楼层
(◔◡◔)不怕丢,妥妥的
发表于 2019-4-15 09:12:32 | 显示全部楼层
有空尝试下node-red 自带的github功能,新建项目的时候可以让你登陆github同步上去的。
发表于 2019-4-15 09:29:47 | 显示全部楼层
谢谢分享,你们的知识太广了,知识无涯,看看点赞
 楼主| 发表于 2019-4-15 14:07:29 | 显示全部楼层
neroxps 发表于 2019-4-15 09:12
有空尝试下node-red 自带的github功能,新建项目的时候可以让你登陆github同步上去的。 ...
请问自带的github功能是在settings里配置吗,还是安装什么节点
发表于 2019-4-15 14:35:29 | 显示全部楼层
不需要,你试试右上角的新建项目,会让你输入github信息的。
 楼主| 发表于 2019-4-15 16:59:42 | 显示全部楼层
右上角没找到新建项目
发表于 2019-4-15 17:03:43 | 显示全部楼层
yinzhennan 发表于 2019-4-15 16:59
右上角没找到新建项目
诶 怎么咱的node-red不一样
 楼主| 发表于 2019-4-15 18:11:52 | 显示全部楼层
neroxps 发表于 2019-4-15 17:03
诶 怎么咱的node-red不一样
我可能装了个假node-red (捂脸
活跃会员教程狂人
发表于 2019-4-22 19:29:38 | 显示全部楼层
这个很好,留着备用。
所有过往,皆为序章。
GMT+8, 2025-12-16 15:51 , Processed in 1.355665 second(s), 9 queries , MemCached On.
