查看: 5408|回复: 5
[求助] 请教关于HA 91.2自定义按钮的问题
发表于 2019-4-14 06:56:28 | 显示全部楼层 |阅读模式
我用以下代码定义的开关是那种按下后在开/关两种状态来回切换的模式,现在想实现按钮按下就发送信号,没有开关状态,用于控制音量不需要开关切换。请问如何实现。
  - platform: template
    switches:
      blu_ray_disc:
        friendly_name: "控制.蓝光影院"
        value_template: "{{ as_timestamp(states.script.blu_ray_disc_off.attributes.last_triggered)  | int  < as_timestamp(states.script.blu_ray_disc_on.attributes.last_triggered)  | int }} "
        turn_on:
          service: script.blu_ray_disc_on
        turn_off:
          service: script.blu_ray_disc_off
发表于 2019-4-14 13:37:50 | 显示全部楼层
直接用script 就是你要的了
 楼主| 发表于 2019-4-14 21:04:01 | 显示全部楼层
lawsongsong 发表于 2019-4-14 13:37
直接用script 就是你要的了
我本来就是用script,问题是做出来的是个开关,我要弄的是按钮,可以通过按压重复发送音量控制信号,不要在开关之间切换。
configuration.yaml
      yl_z:
        command:
          - raw:"Z6WXAZcBAAAfAgAAlAIAAMMFAAAlBgAAexAAAJcQAABuIQAA/2kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABXQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBV0ERQRERQRFBEUERQTIRQRERQRFBAhEREUERQRFBQUFBgVdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQYFnQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBZ0ERQRERQRFBEUERQUERQRERQRFBEREREUERQRFBQUFBgWdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQQE="
      yl_j:
        command:
          - raw:"Z6XbASICAAAaBgAAihAAAGwhAAABagAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBAA"
scripts.yaml
gfyl_z:
  sequence:
    - service: remote.send_command
      entity_id: 'remote.hometheater_remote'
      data:
        command:
          - 'Z6WXAZcBAAAfAgAAlAIAAMMFAAAlBgAAexAAAJcQAABuIQAA/2kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABXQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBV0ERQRERQRFBEUERQTIRQRERQRFBAhEREUERQRFBQUFBgVdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQYFnQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBZ0ERQRERQRFBEUERQUERQRERQRFBEREREUERQRFBQUFBgWdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQQE='
gfyl_j:
  sequence:
      data:
        command:
          - 'Z6XbASICAAAaBgAAihAAAGwhAAABagAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBAA'
发表于 2019-4-15 00:57:26 | 显示全部楼层
ptlzx 发表于 2019-4-14 21:04
我本来就是用script,问题是做出来的是个开关,我要弄的是按钮,可以通过按压重复发送音量控制信号,不要 ...
yl_z:
  command:
yl_j:
  command:
以上删除,用script 就好了
 楼主| 发表于 2019-4-16 17:37:13 | 显示全部楼层
lawsongsong 发表于 2019-4-15 00:57
yl_z:
  command:
    - raw:"Z6WXAZcBAAAfAgAAlAIAAMMFAAAlBgAAexAAAJcQAABuIQAA/2kAAAAAAAAAAAAAAAAAAA ...
搞定了,谢谢啊。
发表于 2022-9-9 17:15:33 | 显示全部楼层
ptlzx 发表于 2019-4-16 17:37
搞定了,谢谢啊。
如何搞定的?我看了一头雾水
GMT+8, 2025-12-23 11:06 , Processed in 0.240927 second(s), 7 queries , MemCached On.
