查看: 8517|回复: 2
[已解决] HA升级0.49.1版本报错
发表于 2017-7-27 17:13:57 | 显示全部楼层 |阅读模式
树莓派3b安装ha,hb都正常。今天发现有更新,按照官网指引手动输入命令pip3 install --upgrade homeassistant进行更新。最后报错,好像是权限问题,使用的用户是pi。求大神分析!
Exception:
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 295, in run
    requirement_set.install(install_options, global_options, root=options.root_path)
  File "/usr/lib/python3/dist-packages/pip/req.py", line 1436, in install
    requirement.install(install_options, global_options, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/pip/req.py", line 672, in install
    self.move_wheel_files(self.source_dir, root=root)
  File "/usr/lib/python3/dist-packages/pip/req.py", line 902, in move_wheel_files
    pycompile=self.pycompile,
  File "/usr/lib/python3/dist-packages/pip/wheel.py", line 214, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/usr/lib/python3/dist-packages/pip/wheel.py", line 204, in clobber
    os.makedirs(destdir)
  File "/usr/lib/python3.4/os.py", line 237, in makedirs
    mkdir(name, mode)
PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.4/dist-packages/homeassistant-0.49.1.dist-info'
Storing debug log for failure in /home/pi/.pip/pip.log
pip.log日志中的报错为
Exception:
    mkdir(name, mode)
已解决。。。确实是权限问题,前面忘记加sudo。。
发表于 2017-7-27 17:45:09 | 显示全部楼层
难道不是权限问题?   升级命令前面加上 sudo啊
iLee
iLee
发表于 2017-7-28 09:19:44 | 显示全部楼层
亲加 sudo pip3 install --upgrade homeassistant
GMT+8, 2025-12-25 15:52 , Processed in 0.330413 second(s), 12 queries , MemCached On.
