查看: 13820|回复: 11
[求助] 如何自定义卡片中switch右边按钮的图标
发表于 2019-4-11 17:56:48 | 显示全部楼层 |阅读模式
求助,想把首页卡片中的这两个按钮换了
按钮本身是基于博联rm pro生成的switch里面的command on/off
目前查阅官方文档,只能找到把前面的图标换成mdi:volume-high
想把画红线的框里面的两个闪电按钮,换成mdi:volume-minus和mdi:volume-plus
感激不尽~~
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-4-11 19:49:15 | 显示全部楼层
只能用customize ui
发表于 2019-4-12 09:12:55 | 显示全部楼层
我的switch怎么是开关啊 好奇 两个闪电图标是怎么来的
流水无味
灌水之王
发表于 2019-4-12 12:10:30 | 显示全部楼层
博联遥控出来的都是闪电……
发表于 2019-4-12 14:16:17 | 显示全部楼层
xieahui 发表于 2019-4-12 12:10
博联遥控出来的都是闪电……
sp mini3猫精那个呢?我的就是开关
发表于 2019-4-12 17:22:59 | 显示全部楼层
无状态反馈的就是这种。switch有参数可以强制指定!
 楼主| 发表于 2019-4-12 17:55:12 | 显示全部楼层
我是想把图标换了
发表于 2019-4-12 23:20:17 | 显示全部楼层
楼主分享下音量控制的代码,谢谢啊
发表于 2019-4-13 07:45:53 | 显示全部楼层
我使用以下代码设置的音量开关,按压后非开即关,不能按下又恢复到关闭状态,无法实现重复按压发送音量增减操作。
configuration.yaml
      yl_z:
        command:
          - raw:"Z6WXAZcBAAAfAgAAlAIAAMMFAAAlBgAAexAAAJcQAABuIQAA/2kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABXQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBV0ERQRERQRFBEUERQTIRQRERQRFBAhEREUERQRFBQUFBgVdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQYFnQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBZ0ERQRERQRFBEUERQUERQRERQRFBEREREUERQRFBQUFBgWdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQQE="
      yl_j:
        command:
          - raw:"Z6XbASICAAAaBgAAihAAAGwhAAABagAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBAA"
scripts.yaml
gfyl_z:
  sequence:
    - service: remote.send_command
      entity_id: 'remote.hometheater_remote'
      data:
        command:
          - 'Z6WXAZcBAAAfAgAAlAIAAMMFAAAlBgAAexAAAJcQAABuIQAA/2kAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABXQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBV0ERQRERQRFBEUERQTIRQRERQRFBAhEREUERQRFBQUFBgVdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQYFnQRFBERFBEUERQRFBQRFBERFBEUERERERQRFBEUFBQUGBZ0ERQRERQRFBEUERQUERQRERQRFBEREREUERQRFBQUFBgWdBEUEREUERQRFBEUFBEUEREUERQRERERFBEUERQUFBQQE='
gfyl_j:
  sequence:
      data:
        command:
          - 'Z6XbASICAAAaBgAAihAAAGwhAAABagAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBBAIxAAEAAAEAAQABAAEBAAEAAQEAAQAAAAAAAAEAAQEBAQQCMQABAAABAAEAAQABAQABAAEBAAEAAAAAAAABAAEBAQEEAjEAAQAAAQABAAEAAQEAAQABAQABAAAAAAAAAQABAQEBAA'
 楼主| 发表于 2019-4-14 16:47:53 | 显示全部楼层
ptlzx 发表于 2019-4-12 23:20
楼主分享下音量控制的代码,谢谢啊
我的本质上是一样的长按连续发送不行。
我现在的红外的主要作用是这样:
由于我的客厅设备较多,逐一用遥控器打开投影、功放、HTPC、天猫魔盒会比较麻烦
于是用aqara的面板开关加上自动化一键控制,同时hass的前端增加了直接点击的按钮
现在的定义是:
双击 一键打开所有设备
长按 一键关闭所有设备
同时按 切换HTPC或天猫魔盒信号源
单击左键 音量功放增加(遥控器原来的信号是按一次调整0.5dB,我设置为发送6次)
单击右键 音量功放减少
所以hass前端现在对我来说是备用渠道。需求不强烈
虽然同时打算在hass前端增加一个静音。
GMT+8, 2025-12-24 07:04 , Processed in 0.199077 second(s), 9 queries , MemCached On.
