楼主: star_liu
[进阶教程] 40元的ESP32-CAM刷ESPHOME接入HASS
wktm 手机认证
发表于 2020-5-15 13:01:47 | 显示全部楼层
学习学习
ppkk
发表于 2020-5-15 13:25:02 | 显示全部楼层
xuexixuexi
发表于 2020-5-15 15:39:56 | 显示全部楼层
感谢分享 学习了
发表于 2020-5-15 16:03:39 | 显示全部楼层
学习学习学习
发表于 2020-5-15 19:29:57 | 显示全部楼层
查看、解锁内容看看
发表于 2020-5-15 20:36:12 | 显示全部楼层
学习天天向上好好学习
wktm 手机认证
发表于 2020-5-16 00:13:12 | 显示全部楼层
用ESPhome 生成的固件用ESPHome-Flasher-1.2.0-windows-x64刷写 ,每次都能这样提示:
Unexpected error: Error while retrieving firmware file 'https://raw.githubusercontent.com/espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_40m.bin': ('Connection aborted.', ConnectionResetError(10054, '远程主机强迫关闭了一个现有的连接。', None, 10054, None))
:Using 'COM5' as serial port.
Connecting.....
Detecting chip type... ESP32
Connecting...
界面启动时候正常
Chip Info:
- Chip Family: ESP32
- Chip Model: ESP32D0WDQ6 (revision 1)
- Number of Cores: 2
- Max CPU Frequency: 240MHz
- Has Bluetooth: YES
- Has Embedded Flash: NO
- Has Factory-Calibrated ADC: YES
- MAC Address: F0:081:CC:8C:B0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
- Flash Size: 4MB
Unexpected error: Error while retrieving firmware file 'https://raw.githubusercontent.com/espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_40m.bin': HTTPSConnectionPool(host='raw.githubusercontent.com', port=443): Max retries exceeded with url: /espressif/arduino-esp32/1.0.4/tools/sdk/bin/bootloader_dio_40m.bin (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x0000014408DEF088>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
发表于 2020-5-16 11:40:44 | 显示全部楼层
看一下坑是什么
发表于 2020-5-17 13:15:04 | 显示全部楼层
解锁看看内容
发表于 2020-5-17 15:07:12 | 显示全部楼层
感谢分享,学习方法。
GMT+8, 2025-12-15 00:02 , Processed in 0.061085 second(s), 16 queries , MemCached On.
