查看: 6722|回复: 11
[求助] 净化器修改了IP跟token显示这个错误 是啥意思
发表于 2019-4-9 01:08:26 | 显示全部楼层 |阅读模式
求助 净化器修改了IP跟token显示这个错误 是啥意思》?
发表于 2019-4-9 06:51:43 | 显示全部楼层
感觉是别的问题,贴一下你的配置
 楼主| 发表于 2019-4-9 11:26:08 | 显示全部楼层
natic 发表于 2019-4-9 06:51
感觉是别的问题,贴一下你的配置
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 32.0617
  longitude: 118.7778
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: [url]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
  time_zone: Asia/Shanghai
  customize_glob:
      custom_ui_state_card: state-card-custom-ui
  # Customization file
customizer:
  custom_ui: local
  hide_attributes:
    - node_id
    - value_index
frontend:
  extra_html_url:
    - /local/custom_ui/state-card-custom-ui.html
  extra_html_url_es5:
    - /local/custom_ui/state-card-custom-ui-es5.html
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
#introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
# Sensors
  # Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
fan:
  - platform: xiaomi_miio
    name: Xiaomi Air Purifier 2
    host: 192.168.1.57
    token: 3d8de126addffaf3cbf99911a3613c4b
group: !include groups.yaml
#automation: !include automations.yaml
script: !include scripts.yaml
homekit:
 楼主| 发表于 2019-4-9 11:43:38 | 显示全部楼层
感觉是别的问题,贴一下你的配置
 楼主| 发表于 2019-4-9 11:45:07 | 显示全部楼层
感觉是别的问题,贴一下你的配置
帮忙看一下,感谢
发表于 2019-4-9 12:04:07 | 显示全部楼层
166513296 发表于 2019-4-9 11:26
[code]homeassistant:
配置没毛病,修改ip和token啥意思?
 楼主| 发表于 2019-4-9 15:37:12 | 显示全部楼层
https://bbs.hassbian.com/forum.p ... mp;highlight=空气
用的是别人的 packages 改了自己空净的IP跟token,这个文件不放到packages 里检查配置正常,文件放进去就提示第一个截图的错误,是customUI我安装的不对么
发表于 2019-4-9 17:30:39 | 显示全部楼层
166513296 发表于 2019-4-9 15:37
https://bbs.hassbian.com/forum.php?mod=viewthread&tid=6143&highlight=空气
用的是别人的 packages  ...
你把custom ui的配置删除掉再看看报错不
 楼主| 发表于 2019-4-9 19:09:33 | 显示全部楼层
文档清空了还是报错,把文件删除就不报了 但是界面UI不显示
 楼主| 发表于 2019-4-9 19:11:27 | 显示全部楼层
GMT+8, 2025-12-24 05:11 , Processed in 0.510756 second(s), 11 queries , MemCached On.
