查看: 7511|回复: 5
[求助] 0.91是不是不支持中弘网关插件了?
发表于 2019-4-8 19:20:16 | 显示全部楼层 |阅读模式
我想问一下,是不是0.91版本是不是不支持中弘网关插件了,总是报错
发表于 2019-4-8 21:44:24 | 显示全部楼层
报错日志贴一下呗
发表于 2019-5-1 01:45:41 | 显示全部楼层
貌似是有问题,近期我修复下。
发表于 2019-7-20 13:05:25 | 显示全部楼层
我也遇到报错了,哪位大佬能帮忙看一下?谢谢!
2019-07-20 13:00:33 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform zhong_hong
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/zhong_hong/climate.py", line 48, in setup_platform
    for (addr_out, addr_in) in hub.discovery_ac()
  File "/usr/local/lib/python3.7/site-packages/zhong_hong_hvac/hub.py", line 191, in discovery_ac
    self.open_socket()
  File "/usr/local/lib/python3.7/site-packages/zhong_hong_hvac/hub.py", line 50, in open_socket
    self.sock = self.__get_socket()
  File "/usr/local/lib/python3.7/site-packages/zhong_hong_hvac/hub.py", line 41, in __get_socket
    s.connect((self.ip_addr, self.port))
ConnectionRefusedError: [Errno 111] Connection refused
发表于 2019-7-24 09:59:39 | 显示全部楼层
2019-07-20 13:00:33 ERROR (MainThread) [homeassistant. ...
重新用docker安装了0.81.2,也提示这个
发表于 2019-7-24 10:01:02 | 显示全部楼层
感觉是某个依赖没安装
GMT+8, 2025-12-16 19:58 , Processed in 0.416769 second(s), 14 queries , MemCached On.
