查看: 5044|回复: 3
[求助] 请教HAdashboard连接问题
发表于 2019-4-4 10:35:36 | 显示全部楼层 |阅读模式
HADashboard反复断连
2019-04-04 10:33:09.254309 INFO AppDaemon: HASS: Connected to Home Assistant 0.90.2
2019-04-04 10:33:09.254747 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-04-04 10:33:14.259691 INFO AppDaemon: HASS: Connected to Home Assistant 0.90.2
2019-04-04 10:33:14.260112 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-04-04 10:33:19.264955 INFO AppDaemon: HASS: Connected to Home Assistant 0.90.2
2019-04-04 10:33:19.265420 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-04-04 10:33:24.270349 INFO AppDaemon: HASS: Connected to Home Assistant 0.90.2
2019-04-04 10:33:24.270807 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2019-04-04 10:33:29.275010 INFO AppDaemon: HASS: Connected to Home Assistant 0.90.2
2019-04-04 10:33:29.275409 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
HA 那边认证是成功的
2019-04-04 10:33:19 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 127.0.0.1 (auth: True)
2019-04-04 10:33:24 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.140396876108240] Disconnected: Did not receive auth message within 10 seconds
2019-04-04 10:33:24 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 127.0.0.1 (auth: True)
2019-04-04 10:33:29 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.140396876111096] Disconnected: Did not receive auth message within 10 seconds
2019-04-04 10:33:29 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 127.0.0.1 (auth: True)
2019-04-04 10:33:34 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.140396875994896] Disconnected: Did not receive auth message within 10 seconds
2019-04-04 10:33:34 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 127.0.0.1 (auth: True)
2019-04-04 10:33:39 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.140396875993608] Disconnected: Did not receive auth message within 10 seconds
2019-04-04 10:33:39 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 127.0.0.1 (auth: True)
2019-04-04 10:33:44 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection.140396876215352] Disconnected:
appdaemon配置文件
appdaemon:
  threads: 10
  plugins:
    HASS:
      type: hass
      ha_url: http://0.0.0.0:8123                               #ha访问地址
      api_password: abc54321
configuration.yaml配置文件
http:
  trusted_networks:
  - 127.0.0.1
请教下为什么会一直断连?
发表于 2019-4-4 11:32:57 | 显示全部楼层
 楼主| 发表于 2019-4-4 11:57:26 | 显示全部楼层
neroxps 发表于 2019-4-4 11:32
https://www.home-assistant.io/components/http/#api_password
好的,谢谢,我了解下。
发表于 2019-8-17 21:07:44 | 显示全部楼层
atlantis007 发表于 2019-4-4 11:57
好的,谢谢,我了解下。
解决了吗?
GMT+8, 2025-12-24 00:52 , Processed in 0.161188 second(s), 13 queries , MemCached On.
