查看: 11665|回复: 8
[基础教程] 新手请教packages的事情
发表于 2019-3-27 23:54:14 | 显示全部楼层 |阅读模式
新手请教,群晖安装的hass,在homeassistan文件夹下新建了packages文件夹,复制了其他人的yaml文件(比如和风天气插件),然后在configuration.yaml修改,增加了packages: !include_dir_named packages,但是在配置-通用-配置重载-配置检查中,总是有错误,显示配置无效Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor/。但是我在群晖的docker-容器-重启后,可以进入ha。请教应该怎么解决配置检查的问题(新手学习中,需不断试用配置检查)。看过一些帖子,把automations.yaml文件中的[]删除也不行,删除configuration.yaml文件中的automation: !include automations.yaml也不行,修改成#automation: !include automations.yaml也不行。
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude:
  longitude:
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
发表于 2019-3-28 01:15:46 | 显示全部楼层
缩进问题 packages 第二级
 楼主| 发表于 2019-3-28 07:41:40 | 显示全部楼层
是缩进了啊
homeassistant:
  latitude:
  longitude:
  elevation: 0
  unit_system: metric
  # Pick yours from here: [url]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
流水无味
灌水之王
发表于 2019-3-28 08:05:07 | 显示全部楼层
你的别人的 yaml文件发上来看看
发表于 2019-3-28 08:16:48 | 显示全部楼层
homeassistant:
  latitude:
  longitude:
  elevation: 0
  unit_system: metric
  # Pick yours from here: [url=http://en.wikipedia.org/wiki/List_of_tz_database_time_zones]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
group: !include groups.yaml
script: !include scripts.yaml
 楼主| 发表于 2019-3-28 15:14:09 | 显示全部楼层
这是我的configuration.yaml
homeassistant:
  latitude:
  longitude:
  elevation: 0
  unit_system: metric
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# 传感器
# Text to speech
tts:
  - platform: google
 楼主| 发表于 2019-3-28 15:18:58 | 显示全部楼层
这是homeassistant\packages\  文件夹的heweather.yaml文件
  - platform: heweather
    city: shanghai
    appkey: cece7677b23827608881ffa266c73cd9
    options:
      - temprature
      - humidity
      - pm25
      - no2
      - so2
      - co
      - o3
      - qlty
  - platform: heweather_hourlyforecast
    city: shanghai
    options:
      - remind
      - 3hour
      - 6hour
      - 9hour
weather:
    - platform: heweather_forecast
      city: shanghai
group:
  weather:
    view: no
    entities:
      - weather.localweather
  heweatherAQI:
    view: no
    entities:
      #- sensor.sensor.heweather_humidity
      #- sensor.heweather_temperature
      - sensor.heweather_qlty
      - sensor.heweather_no2
      - sensor.heweather_pm25
      - sensor.heweather_co
      - sensor.heweather_so2
      - sensor.heweather_o3
  hourlyforecast:
    view: no
    entities:
      - sensor.remind
      - sensor.hourly_forcast_3
      - sensor.hourly_forcast_6
      - sensor.hourly_forcast_9
 楼主| 发表于 2019-3-28 15:21:12 | 显示全部楼层
关键是在群晖的docker-容器-重启后,可以进入ha,而且和帖子的教程里面一下正常显示天气了,但是在配置-通用-配置重载-配置检查中,总是有错误,显示配置无效Invalid config for [sensor]: required key not provided @ data['platform']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor/
发表于 2019-7-5 16:59:45 | 显示全部楼层
我的同样问题,安装斐讯DC1插件是一样显示:
nvalid config for [switch.phicomm_dc1m]: required key not provided @ data['192.168.123.107']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.phicomm_dc1m/。求教大神。
GMT+8, 2026-1-1 15:45 , Processed in 0.499979 second(s), 11 queries , MemCached On.
