查看: 5999|回复: 2
[已解决] sonoff 的sensor pir如何通过sonoff rf bridge 无线接入HA
发表于 2019-3-27 16:57:07 | 显示全部楼层 |阅读模式
emm可能说的题目有点不伦不类,就是我入手一个sonoff rf bridge然后跟着xz0609刷了Tasmota中文固件v6.4.1版,然后也刷了Portisch的EFM8BB1固件,因为买的sonoff送了一个人体传感器,433的,然后能够读出码,就是能否把这个人体红外接入HA呢,不接线的话我写了个自动化,就是收到这个数据之后就把这个传感器状态变为触发,这样可行吗?不行的话应该如何接入?有没有大神指导一下。万分感谢
就是现在还有个疑问,为什么我在sonoff控制台看到的主题是这样的:10:01:57 MQT: tele/sonoff/RESULT = {"RfReceived":{"Sync":12770,"Low":360,"High":1190,"Data":"AE13E9","RfKey":"None"}}
然后我在配置文件中写的这样的:
state_topic: "tele/sonoff/RESULT"
然后HA会跳警告这样的:
No matching payload found for entity: pir wherever with state_topic: tele/sonoff/RESULT有没有大神可以解答一下,感觉一团雾水
解决方法:
配置文件添加
binary_sensor:
  - platform: mqtt
    name: "pir wherever"
    payload_on: "E7DBEE"
    payload_off: "E7DBEEoff"
    device_class: motion
    value_template: '{{ value_json.RfReceived.Data }}'
自动化添加,自动化为将传感器状态改为未触发
- alias: rf_receive
  initial_state: true
  hide_entity: false
  trigger:
    platform: state
    entity_id: binary_sensor.pir_wherever
    to: 'on'
  action:
    - delay:
        seconds: 5
    - service: mqtt.publish
      data:
        payload: '{"RfReceived":{"Data":"E7DBEEoff"}}'
        retain: "true"
发表于 2019-9-3 21:14:51 | 显示全部楼层
你可以这么修改 不用自动化   就可以 自动会恢复关闭状态
发表于 2019-9-3 21:20:15 | 显示全部楼层
  - platform: mqtt #sonoff brige 433 人体红外接入信息
    payload_on: "089722"
    payload_off: ""
    off_delay: 5
    state_topic: "tele/sonoffRB/RESULT"
GMT+8, 2025-11-7 17:39 , Processed in 0.709965 second(s), 6 queries , MemCached On.
