查看: 6242|回复: 6
依次开关的自动化
aaa
34
发表于 2019-3-25 18:23:08 | 显示全部楼层 |阅读模式
之前这样写的,更新版本后就不可用了,请大佬指导一下,如何实现依次开关设备的自动化,感谢!
  - data:
      entity_id: light.da_ting_4
    service: light.turn_on
  - delay: '[object Object]'
  - data:
      entity_id: light.da_ting_5
  - data:
      entity_id: light.da_ting_6
发表于 2019-3-25 18:47:47 | 显示全部楼层
应该是delay写法不支持了吧,换成-delay: 00:00:00.000这样的格式
发表于 2019-3-25 18:48:14 | 显示全部楼层
查一下官方文档,很简单的
aaa
34
 楼主| 发表于 2019-3-27 10:45:14 | 显示全部楼层
这样写好像不行,打开第一个灯后就停止了
佑桑
发表于 2019-3-27 18:25:12 | 显示全部楼层
https://www.home-assistant.io/docs/scripts/
# Waits 1 hour
- delay: '01:00'
# Waits 1 minute, 30 seconds
- delay: '00:01:30'
# Waits 1 minute
- delay:
    # Supports milliseconds, seconds, minutes, hours, days
    minutes: 1
# Waits however many seconds input_number.second_delay is set to
- delay:
    seconds: "{{ states('input_number.second_delay') }}"
# Waits however many minutes input_number.minute_delay is set to
# Valid formats include HH:MM and HH:MM:SS
- delay: "{{ states('input_number.minute_delay') | multiply(60) | timestamp_custom('%H:%M:%S',False) }}"
aaa
34
 楼主| 发表于 2019-3-27 18:44:46 | 显示全部楼层
natic 发表于 2019-3-25 18:48
查一下官方文档,很简单的
感谢指导,解决了
aaa
34
 楼主| 发表于 2019-3-27 18:50:32 | 显示全部楼层
[code]# Waits 1 hour
- delay: '0 ...
感谢指导,想实现毫秒级流动效果但是效果一直不理想,最后也是通过waits解决的
GMT+8, 2025-12-16 20:29 , Processed in 1.262359 second(s), 8 queries , MemCached On.
