查看: 11392|回复: 16
[求助] 小米網關無法接入Homeassistant
发表于 2019-3-14 21:50:54 来自手机 | 显示全部楼层 |阅读模式
一直報錯
Ha version : 89
2019-03-14 10:57:11 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2019-03-14 10:57:14 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:57:14 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2019-03-14 10:57:14 INFO (SyncWorker_8) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 10:57:24 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:57:24 INFO (SyncWorker_8) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 10:57:34 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:58:09 INFO (SyncWorker_8) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-03-14 10:58:09 INFO (SyncWorker_8) [xiaomi_gateway] Creating Multicast Socket
 楼主| 发表于 2019-3-15 00:47:13 | 显示全部楼层
root@homeassistant-home-assistant1:/usr/src/app# ngrep port 9898
interface: eth0 (192.168.1.0/255.255.255.0)
filter: (ip or ip6) and ( port 9898 )
^Cexit
 楼主| 发表于 2019-3-15 01:53:32 | 显示全部楼层
xiaomi_aqara:
  discovery_retry: 3
  interface: 192.168.1.10
  gateways:
    - mac: 7C49EBXXXXXXX
      key: 69c20e4faxxxxxxx
      host: 192.168.1.110
 楼主| 发表于 2019-3-15 01:54:54 | 显示全部楼层
^Cexit
3 received, 0 dropped
^Cexit
2 received, 0 dropped
 楼主| 发表于 2019-3-15 01:57:03 | 显示全部楼层
2019-03-14 17:51:25 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:25 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2019-03-14 17:51:25 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 17:51:35 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:35 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 17:51:45 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:45 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
发表于 2019-3-19 11:33:02 | 显示全部楼层
这问题无解,是网关关闭了对外连接,我新买的网关也是这样,旧的没有问题
 楼主| 发表于 2019-3-21 01:50:14 | 显示全部楼层
fung1006 发表于 2019-3-19 11:33
这问题无解,是网关关闭了对外连接,我新买的网关也是这样,旧的没有问题 ...
所以是舊款才可以??新的没法?
 楼主| 发表于 2019-3-21 01:52:36 | 显示全部楼层
但怎大家都講到好像打幾行指令就可以.....我的不能. 已看很多文章了.
发表于 2019-3-29 00:51:13 | 显示全部楼层
问题已解决
用USB-TTL对网关进行写入,重开它的9898端口
切记新买的网关要先打开“开发者模式“ 后再更新固件, 不然直接更新就会封锁了第三方的接入,HA不能接入
 楼主| 发表于 2019-3-29 12:16:14 | 显示全部楼层
fung1006 发表于 2019-3-29 00:51
问题已解决
請問有相關教學麻? 如何重开它的9898端
GMT+8, 2025-6-28 11:56 , Processed in 0.724106 second(s), 23 queries .
