查看: 16135|回复: 18
[求助] 米家多功能网关怎么接入ha
发表于 2019-3-14 11:07:06 | 显示全部楼层 |阅读模式
日志如下:
2019-03-14 08:34:57 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load
C:\Users\Administrator\AppData\Roaming\.homeassistant\known_devices.yaml: Config file not found: C:\Users\Administrator\AppData\Roaming\.homeassistant\known_devices.yaml
2019-03-14 08:35:07 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2019-03-14 08:35:22 ERROR (SyncWorker_4) [homeassistant.components.xiaomi_aqara] No gateway discovered
2019-03-14 08:35:22 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
配置如下
xiaomi_aqara:
  discovery_retry: 5
  gateways:
    - key: 27bfuv3emaafxxxx
请教大神如何操作
发表于 2019-3-14 12:00:34 | 显示全部楼层
傻瓜式接入。
发表于 2019-3-14 12:02:21 | 显示全部楼层
xiaomi_aqara:
  gateways:
   - mac: xxxxxxxxxxx
     key: 97???o??p2
发表于 2019-3-14 19:19:17 | 显示全部楼层
我也是不能,求教. 都會說Invalid , 然後現在
2019-03-14 10:57:11 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2019-03-14 10:57:14 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:57:14 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2019-03-14 10:57:14 INFO (SyncWorker_8) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 10:57:24 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:57:24 INFO (SyncWorker_8) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 10:57:34 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 10:58:09 INFO (SyncWorker_8) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-03-14 10:58:09 INFO (SyncWorker_8) [xiaomi_gateway] Creating Multicast Socket
发表于 2019-3-14 20:08:58 | 显示全部楼层
与各位一起等答案:)
五岁能抬头
发表于 2019-3-15 00:59:30 | 显示全部楼层
应该是你的配置错了,把你的配置信息贴上来,比如:
xiaomi_aqara:
  discovery_retry: 2
  gateways:
    - mac: xxxxxxxx
      key: xxxxxxxxxxxxxxx
      host: 192.168.x.x
发表于 2019-3-15 01:46:27 | 显示全部楼层
[code]xiaomi_aqara:
  disco ...
xiaomi_aqara:
  discovery_retry: 3
  interface: 192.168.1.10
  gateways:
    - mac: 7C49EBXXXXXXX
      key: 69c20e4faxxxxxxx
      host: 192.168.1.110
发表于 2019-3-15 01:49:56 | 显示全部楼层
[code]xiaomi_aqara:
  disco ...
root@homeassistant-home-assistant1:/usr/src/app# ngrep port 9898
interface: eth0 (192.168.1.0/255.255.255.0)
filter: (ip or ip6) and ( port 9898 )
^Cexit
3 received, 0 dropped
^Cexit
2 received, 0 dropped
发表于 2019-3-15 01:52:27 | 显示全部楼层
[code]xiaomi_aqara:
  disco ...
2019-03-14 17:51:25 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:25 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2019-03-14 17:51:25 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 17:51:35 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:35 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
2019-03-14 17:51:45 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2019-03-14 17:51:45 INFO (SyncWorker_9) [xiaomi_gateway] Discovering Xiaomi Devices
五岁能抬头
发表于 2019-3-15 04:22:25 | 显示全部楼层
1. 网关设备发现(设备发现不加密)
   设备发现用来在局域网中发现网关,使用组播(ip: 224.0.0.50, peer_port: 4321)。
   所有网关收到Whois命令都要应答、回复自己的IP信息。
   PC   组播方式 ->网关:  {"cmd":"whois"}
   网关 单播方式->PC:
   {"cmd":"iam","ip" : "192.168.0.42","port" : "9898","model" : "gateway",.....}
检查一下防火墙设置,4321 和 9898 是否被封了
GMT+8, 2025-11-7 09:57 , Processed in 0.328674 second(s), 7 queries , MemCached On.
