| [32m2017-07-27 04:31:34 INFO (SyncWorker_11) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-mode[0m |
| [31m2017-07-27 04:31:34 ERROR (SyncWorker_13) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-led[0m |
| /bin/sh: 1: node: not found |
| [32m2017-07-27 04:31:34 INFO (SyncWorker_13) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-led[0m |
| [31m2017-07-27 04:31:34 ERROR (SyncWorker_9) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-hum[0m |
| [32m2017-07-27 04:31:34 INFO (SyncWorker_9) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-hum[0m |
| [31m2017-07-27 04:31:34 ERROR (SyncWorker_15) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-temp[0m |
| [32m2017-07-27 04:31:34 INFO (SyncWorker_15) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-temp[0m |
| [31m2017-07-27 04:31:34 ERROR (SyncWorker_18) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-aqi[0m |
| [31m2017-07-27 04:31:34 ERROR (SyncWorker_10) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-power[0m |
| [32m2017-07-27 04:31:34 INFO (SyncWorker_10) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-power[0m |
| [32m2017-07-27 04:31:34 INFO (SyncWorker_18) [homeassistant.components.sensor.command_line] Running command: node airpurifier.js 192.168.50.212 status-aqi[0m |
| [32m2017-07-27 04:31:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_dawn=2017-07-27T21:04:16+00:00, next_dusk=2017-07-27T12:00:34+00:00, next_midnight=2017-07-27T16:32:00+00:00, next_noon=2017-07-27T04:32:00+00:00, next_rising=2017-07-27T21:32:16+00:00, next_setting=2017-07-27T11:32:29+00:00, elevation=74.34, azimuth=178.68, friendly_name=Sun @ 2017-07-27T12:23:30.282575+08:00>, new_state=<state sun.sun=above_horizon; next_dawn=2017-07-27T21:04:16+00:00, next_dusk=2017-07-27T12:00:34+00:00, next_midnight=2017-07-27T16:32:00+00:00, next_noon=2017-07-27T04:32:00+00:00, next_rising=2017-07-27T21:32:16+00:00, next_setting=2017-07-27T11:32:29+00:00, elevation=74.34, azimuth=179.56, friendly_name=Sun @ 2017-07-27T12:23:30.282575+08:00>>[0m |
| [31m2017-07-27 04:30:34 ERROR (SyncWorker_11) [homeassistant.components.sensor.command_line] Command failed: node airpurifier.js 192.168.50.212 status-mode[0m |
