查看: 7765|回复: 6
[已解决] homebridge连接homeassisant鉴权问题
发表于 2019-3-4 16:55:34 | 显示全部楼层 |阅读模式
homeassisant中已经添加http:
   api_password:Raspberry123
configuration.yaml如下:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 27.5066
  longitude: 120.5101
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Asia/Shanghai
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
        http:
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Allow diagnosing system problems
system_health:
# Sensors
  # Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
homebridge中config.json配置为
  "bridge": {
    "name": "Home Assistant",
    "pin": "123-45-678",
    "port": 51826,
    "username": "B8:27:EB:E0D:9A"
  "description": "Homebridge for Home Assistant",
  "platforms": [
      "platform": "HomeAssistant",
      "name": "HomeAssistant",
      "host": "http://192.168.31.175:8123",
      "password": "Raspberry123",
      "supported_types": ["fan", "binary_sensor", "sensor", "garage_door", "input_boolean", "light", "lock", "media_player", "rollershutter", "scene", "switch"],
      "default_visibility": "visible",
      "logging": true
启动homebridge连接过程一直提示鉴权失败是什么问题呢,状态如下
(node:1344) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
[2019/3/4 上午8:54:17] Loaded config.json with 0 accessories and 1 platforms.
[2019/3/4 上午8:54:17] ---
[2019/3/4 上午8:54:18] Loaded plugin: homebridge-homeassistant
[2019/3/4 上午8:54:18] Registering platform 'homebridge-homeassistant.HomeAssistant'
[2019/3/4 上午8:54:18] ---
[2019/3/4 上午8:54:18] Loading 1 platforms...
[2019/3/4 上午8:54:18] [HomeAssistant] Initializing HomeAssistant platform...
[2019/3/4 上午8:54:18] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:18] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:23] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:23] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:28] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:28] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:33] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:33] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:38] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:38] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:43] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:43] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:48] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:48] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2019/3/4 上午8:54:53] [HomeAssistant] Fetching HomeAssistant devices.
[2019/3/4 上午8:54:53] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
发表于 2019-3-4 17:08:00 | 显示全部楼层
homebridge 的homeassistant插件已停止维护
发表于 2019-3-4 17:18:06 | 显示全部楼层
直接用homeassistant吧,放弃HB了,在configuration.yaml里面加homekit:
 楼主| 发表于 2019-3-4 20:48:11 | 显示全部楼层
好的  感谢,新手刚学不清楚技术发展
发表于 2019-3-5 00:32:32 | 显示全部楼层
应该是这样
http:
  api_password: Raspberry123
发表于 2019-8-24 17:31:07 | 显示全部楼层
同样的问题,请问楼主解决了吗?
发表于 2020-1-29 00:12:14 | 显示全部楼层
同样的问题,请问怎么解决了的,一直查不到问题所在,主要hass里的集成hb不能使用camera组件,只能使用hb独立的。
GMT+8, 2025-12-23 16:44 , Processed in 0.124995 second(s), 9 queries , MemCached On.
