查看: 6311|回复: 4
[求助] L大的 百度识别 摄像头图片保存路径问题
发表于 2019-3-2 16:04:59 | 显示全部楼层 |阅读模式
我的是用的N1刷的hassio,日志提示没找到摄像头图片,日志如下:
2019-03-02 15:57:20 ERROR (MainThread) [homeassistant.helpers.entity] Update for image_processing.facerec fails
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
    await self.async_device_update()
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 347, in async_device_update
    await self.async_update()
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/image_processing/__init__.py", line 138, in async_update
    await self.async_process_image(image.content)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/image_processing/baidu_face_indentify.py", line 412, in process_image
    self.get_picture()
  File "/config/custom_components/image_processing/baidu_face_indentify.py", line 398, in get_picture
    with open(self.unknowns_face_path, 'wb') as fo:
FileNotFoundError: [Errno 2] No such file or directory: '/config/facerecognition/face.jpg'
摄像头和识别的配置如下
image_processing:
  - platform: baidu_face_indentify
    app_id: 156*****
    api_key: MNV*****
    secret_key: TLW*****
    snapshot_filepath: /config/facerecognition
    resize: 0
    detect_top_num: 3
    ha_url: [url=http://192.168.3.214:8123]http://192.168.3.214:8123[/url]
    ha_password: password
    scan_interval: 1
    source:
     - entity_id: camera.lidicn_web_cam
#大华摄像头
camera:
  - platform: ffmpeg
    input: -rtsp_transport tcp -i [url=rtsp://admin:[email protected]:554]rtsp://admin:[email protected]:554[/url]
    ffmpeg_bin: /config/facerecognition
    entity_id: lidicn_web_cam
    extra_arguments: -pred 1 -q:v 2 -s 720x480
/config/facerecognition 这个路径是自动创建的还是得手动创建呢?建到哪个目录下呢?谢谢
我创建了 以下目录 均是以上提示。。。
/usr/config/facerecognition
/usr/share/config/facerecognition
/usr/share/hassio/config/facerecognition
/usr/share/hassio/homeassistant/config/facerecognition
教程狂人论坛风云人物突出贡献
发表于 2019-3-2 22:27:04 | 显示全部楼层
/config/facerecognition 应该是这个,
最好通过samba建立这个文件夹, 确保ha具备读写权限.
原理是通过ha的api  获取到摄像头的图片, 存到这个路径里, 供人脸识别调用,
那个摄像头的entityid 要换成你自己的
发表于 2019-3-2 23:36:15 | 显示全部楼层
这个目录就是你的“配置文件.yaml”的目录。建立一个facerecognition的文件夹。
我还没有开始弄。
 楼主| 发表于 2019-3-3 14:03:26 | 显示全部楼层
原理是通过ha的a ...
谢谢
已经可以读取到图片了,标记下 路径
/usr/share/hassio/homeassistant/facerecognition
 楼主| 发表于 2019-3-3 15:23:15 | 显示全部楼层
这个目录就是你 ...
谢谢
GMT+8, 2025-12-24 07:28 , Processed in 0.289999 second(s), 5 queries , MemCached On.
