查看: 14633|回复: 14
[插件集成] 更新 0.88 后broadlink 空调插件变更
发表于 2019-2-21 11:14:08 | 显示全部楼层 |阅读模式
今天更新HA到0.88后,发现原来的broadlink 空调插件不能用了,发现github已经更新
Climate ComponentInstallation:Create a new folder into the Home Assistant's custom_components folder and name it smartir. Copy climate.py into the smartir folder. Create the subfolders codes/climate into the smartir folder and copy the code file for your AC device.
Configuration variables:name (Optional): Name to use in the frontend
device_code (Required): ...... (Accepts only positive numbers)
controller_send_service (Required): The service that will be used to send the commands. Only broadlink_send_packet (Broadlink controller) is currently supported.
temperature_sensor (Optional): entity_id for a temperature sensor
humidity_sensor (Optional): entity_id for a humidity sensor
power_sensor (Optional): entity_id for a sensor that monitors whether your device is actually On or Off. This may be a power monitor sensor. (Accepts only on/off states)
Example (using broadlink controller):switch:  - platform: broadlink    host: 192.168.10.10    mac: '00:00:00:00:00:00'    climate:  - platform: smartir    name: Office AC    device_code: 1000    controller_send_service: switch.broadlink_send_packet_192_168_10_10    temperature_sensor: sensor.temperature    humidity_sensor: sensor.humidity    power_sensor: binary_sensor.ac_power
https://github.com/smartHomeHub/SmartIR
SmartIR-master.zip
737.21 KB, 下载次数: 83
参与人数 1金钱 +10 HASS币 +10 收起 理由
Roger + 10 + 10 感谢楼主分享!
发表于 2019-2-21 16:29:19 | 显示全部楼层
谢谢楼主分享!
发表于 2019-2-23 01:01:58 | 显示全部楼层
继续学习
发表于 2019-2-23 15:08:30 | 显示全部楼层
media player 插件出现错误,但是空调插件没事,不知道为啥
 楼主| 发表于 2019-2-23 22:27:34 | 显示全部楼层
也更新了
SmartIR-master(1).zip
764.36 KB, 下载次数: 16
 楼主| 发表于 2019-2-23 22:38:47 | 显示全部楼层
media_player:
- platform: smartir
    name: Living room TV
    device_code: 1000
    controller_send_service: switch.broadlink_send_packet_192_168_1_10
    power_sensor: binary_sensor.living_room_tv
binary_sensor:
  - platform: ping
    host: 192.168.1.11
    scan_interval: 5
    count: 5
发表于 2019-2-23 23:23:48 | 显示全部楼层
谢谢分享
流水无味
灌水之王
发表于 2019-2-25 11:08:13 | 显示全部楼层
额 悠着点
发表于 2019-2-25 20:39:55 | 显示全部楼层
zwbjsnt 发表于 2019-2-23 22:38
media_player:
- platform: smartir
谢谢老板。问题已解决。
我就是六神
活跃会员教程狂人灌水之王
发表于 2019-3-1 22:06:42 | 显示全部楼层
顶一下~
GMT+8, 2025-10-4 02:42 , Processed in 0.057428 second(s), 11 queries , MemCached On.
