查看: 4320|回复: 1
[求助] 升级到Home Assistant 0.87.1后的问题
发表于 2019-2-15 22:40:47 | 显示全部楼层 |阅读模式
light.mqtt  switch.mqtt  sensor.mqtt 出现问题
2019-02-15 14:18:29 ERROR (MainThread) [homeassistant.components] Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [homebridge_hidden] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->homebridge_hidden. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [sensor.mqtt]: [optimistic] is an invalid option for [sensor.mqtt]. Check: sensor.mqtt->optimistic. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.mqtt/Invalid config for [light.mqtt]: [rgb_command_mode] is an invalid option for [light.mqtt]. Check: light.mqtt->rgb_command_mode. (See ?, line ?). Please check the docs at https://home-assistant.io/components/light.mqtt/
发表于 2019-2-15 23:29:39 | 显示全部楼层
配置文件中移除这些invalid的标签就行了
GMT+8, 2025-12-24 09:20 , Processed in 0.496740 second(s), 13 queries , MemCached On.
