查看: 37628|回复: 25
米家720P云台版破解接入homeassistant
发表于 2019-2-14 22:22:00 | 显示全部楼层 |阅读模式
https://github.com/ghoost82/mijia-720p-hack
原版地址
我来精简了一下
  • 首先降级摄像头:
    fat32格式化tf卡拷贝tf_recovery.img这个文件
    下载地址 c720p.torrent (3.47 KB, 下载次数: 135)
    断电插卡重启降级好后
  • https://github.com/ghoost82/mijia-720p-hack/releases
    下载那个zip包
    然后把sdcard中的内容放在sd卡的根目录下
    修改mijia-720p-hack.cfg文件
    ## Set WIFI STA SSID, when empty no configuration is done
    WIFI_SSID="你的wifi名"
    ## Set WIFI STA password
    WIFI_PASS="你的wifi密码"
    然后断电插卡过会就会成功了
    登陆摄像头IP能登陆就算成功了
    摄像头的mijia-720p-hack.cfg配置文件如下配置
    ## Password for root user, needed for SSH server and Samba R/W access
    ROOT_PASSWORD="1234qwer"
    WIFI_SSID="你的wifi SSID"
    ## Set timezone -> [url]http://svn.fonosfera.org/fon-ng/trunk/luci/modules/admin-fon/root/etc/timezones.db[/url]
    TIMEZONE="UTC"
    ## Prefered NTP server
    NTP_SERVER="pool.ntp.org"
    ## Start syslog (0/1)
    ENABLE_SYSLOG=0
    ## Total Disconnect from Xioami servers, includes disable of streaming and OTA updater (0/1)
    DISABLE_CLOUD=0
    ## Manage the camera via cloud but prevent online updates (0/1)
    DISABLE_OTA=1
    ## Start telnet server at system boot (0/1)
    ENABLE_TELNETD=1
    ## Start SSH server at system boot (0/1)
    ENABLE_SSHD=1
    ## Start web server at system boot (0/1)
    ENABLE_HTTPD=1
    ## Start FTP server at system boot (0/1)
    ENABLE_FTPD=1
    ## Start samba server at system boot (0/1)
    ENABLE_SAMBA=0
    ## Start local streaming server at system boot (0/1)
    ENABLE_RTSP=1
    ## Disable the execution of the hack scripts (0/1)
    DISABLE_HACK=0
    ## Use custom english sound files (0/1) WIP
    SOUND_EN="0"
  • 可选项 RTSP转MJPEG 下载安装VLC将VLC.exe的路径加入到系统环境中path中,
我编写了一个bat文件,可以开启vlc的mjpeg的服务器
@echo off
start cmd /k "cd/d d:\&&echo 开启摄像头&&vlc.exe -R rtsp://摄像头IP/live/ch00_0  --sout "#transcode{vcodec=mjpg,vb=2500,scale=1.0,fps=10,acodec=none}:standard{access=http{mime=multipart/x-mixed-replace; boundary=7b3cc56e5f51db803f790dad720ed50a},mux=mpjpeg,dst=:8888/videostream.cgi}"
MJPEG的网址,可以配置也可以lovelace ui的picture直接加入这个地址就可以看到你的监控了
http://VLC运行机器的IP:8888/videostream.cgi
效果
效果
配置方法
配置方法
参与人数 1金钱 +20 收起 理由
+ 20 厉害了word楼主!
发表于 2019-2-15 09:36:14 | 显示全部楼层
先回复后学习
发表于 2019-2-15 10:23:49 | 显示全部楼层
棒!!手头有个未拆封的。
发表于 2019-2-15 13:36:43 | 显示全部楼层
赞啊!!!
发表于 2019-2-15 17:17:26 | 显示全部楼层
点个赞
发表于 2019-2-15 17:48:57 | 显示全部楼层
感谢楼主分享经验,后排学习收藏了
发表于 2019-2-17 15:32:10 | 显示全部楼层
感谢楼主分享
发表于 2019-2-17 15:36:47 | 显示全部楼层
1080p 的可以用这个固件吗?
发表于 2019-2-17 16:19:10 | 显示全部楼层
感谢楼主分享经验,后排学习了
发表于 2019-2-18 08:16:44 | 显示全部楼层
謝謝大大分享教程
GMT+8, 2025-12-24 09:31 , Processed in 0.343589 second(s), 12 queries , MemCached On.
