查看: 4725|回复: 2
[求助] 升级ha后 发现内置的hk报错
发表于 2019-2-12 17:40:22 | 显示全部楼层 |阅读模式
升级了ha后,发现内置的hk报错
报错如下:
Error during setup of component homekit
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/homekit/__init__.py", line 84, in async_setup
    await hass.async_add_executor_job(homekit.setup)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/homekit/__init__.py", line 218, in setup
    from .accessories import HomeBridge, HomeDriver
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/homeassistant/components/homekit/accessories.py", line 8, in <module>
    from pyhap.accessory_driver import AccessoryDriver
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/pyhap/accessory_driver.py", line 46, in <module>
    from pyhap.hap_server import HAPServer
  File "/srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/pyhap/hap_server.py", line 20, in <module>
    from Crypto.Protocol.KDF import HKDF
ModuleNotFoundError: No module named 'Crypto.Protocol'
 楼主| 发表于 2019-2-12 17:42:00 | 显示全部楼层
请大神们解惑
五岁能抬头
发表于 2019-2-12 20:46:31 | 显示全部楼层
说是找不到模块,试试 pip3 install --upgrade pycrypto
GMT+8, 2025-12-24 07:27 , Processed in 0.260069 second(s), 8 queries , MemCached On.
