查看: 3511|回复: 2
[技术探讨] hassio更新0.87.0 出现错误,请大神~~~~~~~~
发表于 2019-2-10 18:19:20 | 显示全部楼层 |阅读模式
所有自动化都用不了了
Invalid config for [automation]: [hours] is an invalid option for [automation]. Check: automation->trigger->0->hours. (See /config/configuration.yaml, line 80). Please check the docs at https://home-assistant.io/components/automation/Invalid config for [automation]: [hours] is an invalid option for [automation]. Check: automation->trigger->0->hours. (See /config/configuration.yaml, line 80). Please check the docs at https://home-assistant.io/components/automation/
- alias: yugang_on
  initial_state: true
  hide_entity: true
  trigger:
    platform: time
    hours: '/1'
    minutes: 0
    seconds: 0
  condition:
    condition: time
    after: '07:00:00'
    before: '22:00:00'
  action:
    - service: switch.turn_on
      entity_id: switch.dc1_menkou_s1
发表于 2019-2-10 19:59:41 | 显示全部楼层
platform: time 改 platform: time_pattern
参与人数 1金钱 +2 收起 理由
chzyh + 2 在下对你的景仰犹如滔滔长江之水,连绵不绝.
 楼主| 发表于 2019-2-10 20:14:01 | 显示全部楼层
谢谢大神 配置通过了
GMT+8, 2026-1-2 04:26 , Processed in 0.061542 second(s), 9 queries , MemCached On.
