查看: 13214|回复: 12
[技术探讨] 使用Command line Switch添加的开关无法反馈状态
发表于 2019-2-8 18:13:28 | 显示全部楼层 |阅读模式
根据home assistant文档, 使用command line switch组件添加了一个TV的开关.
https://www.home-assistant.io/components/switch.command_line/
switches
(map)(Required)The array that contains all command switches.
identifier
(map)(Required)Name of the command switch as slug. Multiple entries are possible.
command_on
(string)(Required)The action to take for on.
command_off
(string)(Required)The action to take for off.
command_state
(string)(Optional)If given, this command will be run. Returning a result code 0 will indicate that the switch is on.
value_template
(string)(Optional)If specified, command_state will ignore the result code of the command but the template evaluating to true will indicate the switch is on.
friendly_name
(string)(Optional)The name used to display the switch in the frontend.
confrontation.yaml中的代码如下:
switch:
  - platform: command_line
    switches:
      tv:
        command_on: curl "http://192.168.1.6:9876/send?deviceMac=001994362b28&codeId=l1523072382580"
        command_off: curl "http://192.168.1.6:9876/send?deviceMac=001994362b28&codeId=l1523072382580"
        command_state: 'ping -c 1 -W 100 192.168.1.5 &> /dev/null && echo 0||echo 1'
现在无论电视是否开启, 开关的状态都是开启的.
但在ssh下执行ping -c 1 -W 100 192.168.1.5 &> /dev/null && echo 0||echo 1 的命令, 电视开机的状态返回的是0, 关机状态返回的是1. 看起来没有问题.
关机状态:
root@localhost:/home/homeassistant/.homeassistant# ping -c 1 -W 1 192.168.1.5 &> /dev/null && echo 0 || echo 1
开机状态:
mitu 手机认证
发表于 2019-2-8 21:43:15 | 显示全部楼层
用下面的命令试一下看行不行。我以前试过,可以的。
ping -c 1 192.168.1.100 | grep "1 received" | wc -l
 楼主| 发表于 2019-2-9 11:00:16 | 显示全部楼层
ping -c 1 192.168.1.100 | grep "1 received" | wc -l ...
这个在shell下执行结果是反的.
开机状态返回的是1. 关机状态返回的是0.
但实际加到configuration.yaml之后, 这个开关还是永远是开的状态...
发表于 2019-2-9 12:04:45 | 显示全部楼层
过来学习学习
发表于 2019-2-9 15:51:38 | 显示全部楼层
有没有想过是权限的问题,我之前测试Command line sensor的时候,发现hassio可行的代码,docker下homeassistant没有反馈
 楼主| 发表于 2019-2-9 16:20:26 | 显示全部楼层
情非殇 发表于 2019-2-9 15:51
有没有想过是权限的问题,我之前测试Command line sensor的时候,发现hassio可行的代码,docker下homeassis ...
应该不是权限的问题, ping命令应该不需要特殊的权限. 我的homeassistant是用virtulenv安装在ubuntu上. 刚才查了一下log,也没有任何报错...
我怀疑是value passing上出了点问题吧.
发表于 2019-2-9 17:05:12 | 显示全部楼层
befantasy 发表于 2019-2-9 16:20
应该不是权限的问题, ping命令应该不需要特殊的权限. 我的homeassistant是用virtulenv安装在ubuntu上. 刚 ...
不太清楚,我之前用的nz命令查小米盒子6095端口,docker下的homeassistant就没有反馈,hassio可以,ubuntu里直接nz也可以
 楼主| 发表于 2019-2-10 11:36:02 | 显示全部楼层
求助. 有人了解吗?
发表于 2019-7-12 15:23:38 | 显示全部楼层
大佬,搞定没?
 楼主| 发表于 2019-7-15 23:21:55 | 显示全部楼层
没搞定, 后来用template switch+sensor来替代command line switch+ping了。
  - platform: template
    switches:
      aroma:
        value_template: "{{ is_state('switch.aroma', 'on') }}"
        turn_on:
          service: climate.xiaomi_miio_send_command
          data:
            command: 'FE0000000000000000000000000800282250003600AC00E501C803860FB3138825CC4300000000000000000101010101010101000000000000000101010101010101000542074207420699'
        turn_off:
          data:
GMT+8, 2026-1-1 05:29 , Processed in 0.875776 second(s), 9 queries , MemCached On.
