查看: 5349|回复: 2
[已解决] 小米網關無法綁定persistent_notification.invalid_config
发表于 2019-2-2 23:10:08 | 显示全部楼层 |阅读模式
小米網關無法綁定
configuration.yaml 已經打勾沒有錯誤訊息了
但是出現下列訊息
title: Invalid configmessage: The following components and platforms could not be set up: - [xiaomi-aqara](https://home-assistant.io/components/xiaomi_aqara/)Please check your config.
  "title": "Invalid config",
  "message": "The following components and platforms could not be set up:\n\n - [xiaomi-aqara](https://home-assistant.io/components/xiaomi_aqara/)\n\nPlease check your config."
請問各位高手 這是什麼問題呢?
要如何解決
感謝
五岁能抬头
发表于 2019-2-5 03:16:37 | 显示全部楼层
应该是你的配置错了,把你的配置信息贴上来,比如:
xiaomi_aqara:
  discovery_retry: 2
  gateways:
    - mac: xxxxxxxx
      key: xxxxxxxxxxxxxxx
      host: 192.168.x.x
 楼主| 发表于 2019-2-10 22:38:34 | 显示全部楼层
[code]xiaomi_aqara:
  discovery_ret ...
謝謝
已解決
GMT+8, 2025-12-24 09:31 , Processed in 0.314691 second(s), 11 queries , MemCached On.
