楼主: cnk700i
[插件集成] 叮咚音箱、天猫精灵、小度音箱接入HA【支持音箱APP技能】
发表于 2020-3-16 18:27:31 | 显示全部楼层
感谢分析
发表于 2020-3-16 19:47:20 | 显示全部楼层
谢谢分享,,,
发表于 2020-3-16 22:16:30 | 显示全部楼层
发表于 2020-3-17 22:14:12 | 显示全部楼层
大佬,实在搞不定了,请教一下报错原因
自建技能方式,公网ip、ssl证书都正常,技能授权成功,havcs.reload可以生成设备信息,小度无法发现设备
homeassistant日志
2020-03-17 21:55:26 DEBUG (MainThread) [custom_components.havcs] [http] -------- start handle task from http at 2020-03-17 21:55:26 --------
2020-03-17 21:55:26 DEBUG (MainThread) [custom_components.havcs] [http] raw message: {"header":{"payloadVersion":"1","name":"DiscoverAppliancesRequest","namespace":"DuerOS.ConnectedHome.Discovery","messageId":"f20288f0-6856-11ea-8b7f-0304fcba2402_DCS-10-201-43-32-8260-0317215522-525521_8#1_0_Smarthome_5e70d6ce13ec20.85258211"},"payload":{"accessToken":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjMTJhMGJlZmU5NGI0NmZlODVkNmZmYWFkMzZlODQ4NyIsImlhdCI6MTU4NDQ0OTMzMCwiZXhwIjoxNTg0NTM1NzMwfQ.Bqgm5LXm3c0yApazrfm-oV5h9YikCmKzqkGhfn7cWoA","openUid":"eed9c98a711c6918972975ec51d69d70"}}
2020-03-17 21:55:26 DEBUG (MainThread) [custom_components.havcs] [http] get access_token >>> eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjMTJhMGJlZmU5NGI0NmZlODVkNmZmYWFkMzZlODQ4NyIsImlhdCI6MTU4NDQ0OTMzMCwiZXhwIjoxNTg0NTM1NzMwfQ.Bqgm5LXm3c0yApazrfm-oV5h9YikCmKzqkGhfn7cWoA <<<
2020-03-17 21:55:26 DEBUG (MainThread) [custom_components.havcs] [http] validate access_token, get refresh_token(id = c12a0befe94b46fe85d6ffaad36e8487)
2020-03-17 21:55:26 INFO (MainThread) [custom_components.havcs.dueros] [dueros] Handle Request:
{'header': {'payloadVersion': '1', 'name': 'DiscoverAppliancesRequest', 'namespace': 'DuerOS.ConnectedHome.Discovery', 'messageId': 'f20288f0-6856-11ea-8b7f-0304fcba2402_DCS-10-201-43-32-8260-0317215522-525521_8#1_0_Smarthome_5e70d6ce13ec20.85258211'}, 'payload': {'accessToken': 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjMTJhMGJlZmU5NGI0NmZlODVkNmZmYWFkMzZlODQ4NyIsImlhdCI6MTU4NDQ0OTMzMCwiZXhwIjoxNTg0NTM1NzMwfQ.Bqgm5LXm3c0yApazrfm-oV5h9YikCmKzqkGhfn7cWoA', 'openUid': 'eed9c98a711c6918972975ec51d69d70'}}
2020-03-17 21:55:26 ERROR (MainThread) [custom_components.havcs] [http] handle fail: Traceback (most recent call last):
  File "/config/custom_components/havcs/__init__.py", line 657, in post
    response = await HANDLER[platform].handleRequest(json.loads(data), refresh_token)
  File "/config/custom_components/havcs/dueros.py", line 197, in handleRequest
    err_result, discovery_devices, entity_ids = self.process_discovery_command()
  File "/config/custom_components/havcs/helper.py", line 55, in process_discovery_command
    properties = self._discovery_process_propertites(device_properties)
  File "/config/custom_components/havcs/dueros.py", line 268, in _discovery_process_propertites
    properties += [{'name': name, 'value': value, 'scale': scale, 'timestampOfSample': int(time.time()), 'uncertaintyInMilliseconds': 1000, 'legalValue': legalValue }]
UnboundLocalError: local variable 'scale' referenced before assignment
2020-03-17 21:55:26 DEBUG (MainThread) [custom_components.havcs] [http] -------- http task finish at 2020-03-17 21:55:26, running time: 0.04833s --------
发表于 2020-3-18 12:32:05 来自手机 | 显示全部楼层
栩寒 发表于 2020-3-17 22:14
大佬,实在搞不定了,请教一下报错原因
自建技能方式,公网ip、ssl证书都正常,技能授权成功,havcs.reload ...
已解决已解决已解决已解决
发表于 2020-3-18 21:59:40 | 显示全部楼层
看其他帖懵逼了,虽然https+内网穿透玩得很6
发表于 2020-3-18 23:03:28 | 显示全部楼层
学习了,谢谢楼主分享
发表于 2020-3-19 01:03:20 | 显示全部楼层
参考一下········谢谢分享·············
发表于 2020-3-19 11:32:49 | 显示全部楼层
厉害。高级
发表于 2020-3-19 15:02:55 | 显示全部楼层
感谢大神分享
GMT+8, 2025-12-19 00:50 , Processed in 1.272314 second(s), 16 queries , MemCached On.
