ha 从0.84.6升级到0.86以后,自动化部分挂了
日志中没看出什么严重错误,只有这一条
2019-01-28 14:56:18 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
Exception in thread Recorder:
File "/usr/local/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/recorder/__init__.py", line 290, in run
entity_id = event.data.get(ATTR_ENTITY_ID)
AttributeError: 'str' object has no attribute 'get'
2019-01-28 15:05:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication fromIPXXXXXXXX
请大神帮忙分析一下,感谢
