楼主 |
发表于 2019-1-25 01:38:39
显示全部楼层
日志是这样的
Detected device with identifier 111789220 types Set { 'miio' } model xiaomi.repeater.v3
Skip device: 111789220 type:repeater
Detected device with identifier 56803100 types Set { 'sensor', 'miio:gateway', 'miio' } model lumi.gateway.v3
Detected device with identifier 158d0002532d4b types Set { 'miio', 'miio:subdevice', 'sub-thing' } model lumi.generic.18
Unknown model lumi.generic.18
Skip device: 158d0002532d4b type:unknown
Detected device with identifier 88163627 types Set { 'miio:power-plug', 'miio', 'power-outlet', 'power-plug' } model chuangmi.plug.m1
Unknown model chuangmi.plug.m1
Skip device: 88163627 type:unknown
25 Jan 01:31:40 - [red] Uncaught Exception:
25 Jan 01:31:40 - SyntaxError: Unexpected token u in JSON at position 0
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Unit entered failed state.
nodered.service: Failed with result 'exit-code'.
nodered.service: Service hold-off time over, scheduling restart.
Stopped Node-RED graphical event wiring tool.
Started Node-RED graphical event wiring tool. |
