查看: 12477|回复: 11
[技术探讨] 0.82.0升级到最新版本,自动化报错,全部无法使用
发表于 2019-1-24 22:23:08 | 显示全部楼层 |阅读模式
0.82.0升级到最新版本,自动化报错,全部无法使用,求救!
 楼主| 发表于 2019-1-24 22:37:59 | 显示全部楼层
所有的自动化都不能工作,各种报错,降回0.80.0,一切正常,晕死
只发干货
教程狂人论坛风云人物
发表于 2019-1-25 00:22:16 | 显示全部楼层
所有自动化文件,查找platform: time,凡是有hours、minutes、seconds的改成platform: time_pattern;凡是at具体时间的都用platform: time。打完收工!
流水无味
灌水之王
发表于 2019-1-25 07:56:20 | 显示全部楼层
holala 发表于 2019-1-25 00:22
所有自动化文件,查找platform: time,凡是有hours、minutes、seconds的改成platform: time_pattern;凡是a ...
学到一招 点赞,我版本还没升到最高
发表于 2019-1-25 09:34:04 | 显示全部楼层
过两天再升吧 每次新版本感觉总要折腾1-2个小版本
Noteworthy breaking changes
This release also includes two noteworthy breaking changes. One is a follow-up on the slugify breaking change from last release. We did not update the validation check for config options that need to be valid slugs. This means that some of your config values might be invalid. Keep an eye at the console as we have a new message to tell you which ones are wrong.
This issue also impacts the entity registry, which could contain in some rare cases invalid entity IDs. Expect entity IDs to change if they contained a double underscore (which becomes 1) or if they started/ended in an underscore (which will be removed).
Another noteworthy breaking change (sorry!), is that the automation time trigger has been split into two: time and time_pattern. If you had a time trigger containing the keys hours, minutes or seconds, update the platform from time to time_pattern.
https://www.home-assistant.io/docs/automation/trigger/#time-trigger
发表于 2019-1-25 09:37:15 | 显示全部楼层
感觉新版本有点坑啊
发表于 2019-1-25 10:13:48 | 显示全部楼层
答疑解惑哦
 楼主| 发表于 2019-1-25 20:19:28 | 显示全部楼层
谢谢,已经搞定了
 楼主| 发表于 2019-1-25 20:56:54 | 显示全部楼层
已经搞定
发表于 2019-1-30 13:57:25 | 显示全部楼层
解答的很明确
GMT+8, 2026-1-1 22:06 , Processed in 1.609833 second(s), 10 queries , MemCached On.
