查看: 7877|回复: 6
[已解决] MPD运行不了~错误如下,哪位来解答下~
发表于 2017-7-22 12:38:44 | 显示全部楼层 |阅读模式
config_file: loading file /etc/mpd.conf
stderr
02:04:21
server_socket: bind to '0.0.0.0:6600' failed: Address already in use (continuing anyway, because binding to '[::]:6600' succeeded)
stderr
02:04:21
path: SetFSCharset: fs charset is: UTF-8
stderr
02:04:21
libsamplerate: libsamplerate converter 'Fastest Sinc Interpolator'
stderr
02:04:21
vorbis: Xiph.Org libVorbis 1.3.5
stderr
02:04:21
opus: libopus 1.1.2
stderr
02:04:21
sndfile: libsndfile-1.0.25
stderr
02:04:21
wildmidi: configuration file does not exist: /etc/timidity/timidity.cfg
stderr
02:04:21
adplug: adplug 2.2.1
stderr
02:04:21
db: reading DB
stderr
02:04:21
curl: version 7.47.0
stderr
02:04:21
curl: with GnuTLS/3.4.10
stderr
02:04:21
avahi: Initializing interface
stderr
02:04:21
avahi: Failed to create client: Daemon not running
stderr
02:04:21
avahi: Shutting down interface
stderr
02:04:21
state_file: Loading state file /var/lib/mpd/state
stderr
02:04:21
pulse_output: Failed to enable "HAVIT M10" [pulse]: pa_context_connect() has failed: Connection refused
 楼主| 发表于 2017-7-22 13:05:22 | 显示全部楼层
症状:日志看见生成MP3,MPD在HA里播放器没有的,蓝牙音箱群晖已连上但是MPD连不上
laylist: play 0:"http://10.21.33.253:8123/api/tts_proxy/8d09338d3b987334d62308314662f31860b00614_zh_-_baidu.mp3
 楼主| 发表于 2017-7-23 09:56:37 | 显示全部楼层
查到了。代码缩进的问题
发表于 2019-5-8 13:05:54 | 显示全部楼层
yuyakk 发表于 2017-7-23 09:56
查到了。代码缩进的问题
你好,我跟你是一样的问题。请问你是在哪个文件的代码缩进出现了问题呢
 楼主| 发表于 2019-5-10 12:45:14 | 显示全部楼层
sasukebinbin 发表于 2019-5-8 13:05
你好,我跟你是一样的问题。请问你是在哪个文件的代码缩进出现了问题呢 ...
前年的事情吧,时间太长了,不记得了,跟我一样的情况的话,仔细看下代码缩进问题吧。
发表于 2019-5-13 01:41:39 | 显示全部楼层
楼主有用mdp做tts么?我的mdp做tts时需要触发几次才能发声
发表于 2021-11-30 01:34:47 | 显示全部楼层
我也是6600被佔用啦,如何解決啦
GMT+8, 2025-12-22 05:50 , Processed in 0.273673 second(s), 8 queries , MemCached On.
