查看: 10972|回复: 2
[已解决] 请教在群晖 docker 中安装 homebridge容器一旦运行就停止。求助
发表于 2017-7-22 10:57:07 | 显示全部楼层 |阅读模式
设备:群晖docker
对着论坛的教程已经可以再docker中建好了HomeAssistant
如果想要建homebridge 是不是需要再docker 中再建一个容器?
但是现在homebridge按照教程 已经建好
在启动的时候总是在报错
[backcolor=rgb(222, 236, 252) !important]
[0m*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
stdout
02:52:59
*** WARNING *** Please fix your application to use the native API of Avahi!
stdout
02:52:59
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
stdout
02:52:59
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
stdout
02:52:59
stdout
02:52:59
*** WARNING *** For more information see <http://0pointer.de/avahi-compat? ... ServiceRegister>
stdout
02:53:00
npm info it worked if it ends with ok
stdout
02:53:01
npm info using [email protected]
stdout
02:53:01
stdout
02:53:01
npm info ok
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Loaded plugin: homebridge-aqara
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Registering platform 'homebridge-aqara.AqaraPlatform'
stdout
02:53:01
[7/22/2017, 2:53:01 AM] ---
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Loaded plugin: homebridge-synology
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Registering accessory 'homebridge-synology.Synology'
stdout
02:53:01
stdout
02:53:01
failed to load BLE module!
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Loaded plugin: homebridge-yeelight
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Registering platform 'homebridge-yeelight.yeelight'
stdout
02:53:01
stdout
02:53:01
[7/22/2017, 2:53:01 AM] There was a problem reading your config.json file.
stdout
02:53:01
[7/22/2017, 2:53:01 AM] Please try pasting your config.json file here to validate it: http://jsonlint.com
stdout
02:53:01
stdout
02:53:01
/usr/local/lib/node_modules/homebridge/lib/server.js:197
stdout
02:53:01
    throw err;
stdout
02:53:01
stdout
02:53:01
stdout
02:53:01
SyntaxError: Unexpected token  in JSON at position 0
stdout
02:53:01
    at JSON.parse (<anonymous>)
stdout
02:53:01
    at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:191:19)
stdout
02:53:01
    at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:52:38)
stdout
02:53:01
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
stdout
02:53:01
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
stdout
02:53:01
    at Module._compile (module.js:571:32)
stdout
02:53:01
    at Object.Module._extensions..js (module.js:580:10)
stdout
02:53:01
    at Module.load (module.js:488:32)
stdout
02:53:01
    at tryModuleLoad (module.js:447:12)
stdout
02:53:01
    at Function.Module._load (module.js:439:3)
config.json中也是按照要求进行配置的。
发表于 2017-7-22 12:15:08 | 显示全部楼层
你安装了哪些插件,是不是有的插件,但是没有设备,最好能上传安装的插件和json的写法
 楼主| 发表于 2017-7-25 17:39:50 | 显示全部楼层
确实是插件的问提,删除了没有的驱动和插件以后可以运行了。
GMT+8, 2025-12-25 15:52 , Processed in 0.353228 second(s), 6 queries , MemCached On.
