查看: 4235|回复: 5
[求助] n1搭建的ha 接入鸿雁智能插排 出现报错
发表于 2019-1-22 15:42:59 | 显示全部楼层 |阅读模式
Not initializing switch.broadlink because could not install requirement broadlink==0.9.0Unable to install package broadlink==0.9.0: python-jose-cryptodome 1.3.2 has requirement pycryptodome<3.4.0,>=3.3.1, but you'll have pycryptodome 3.7.3 which is incompatible.broadlink 0.9 has requirement pycryptodome==3.4.11, but you'll have pycryptodome 3.7.3 which is incompatible.Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-y3kkkh2z/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-rmh2i9yc/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.6/pycryptodome" failed with error code 1 in /tmp/pip-install-y3kkkh2z/pycryptodome/
发表于 2019-1-22 16:34:48 | 显示全部楼层
猜测是pip源问题,没法安装博联的依赖。
 楼主| 发表于 2019-1-22 18:10:59 | 显示全部楼层
有办法安装吗?
发表于 2019-1-23 20:07:59 | 显示全部楼层
zzx386 发表于 2019-1-22 18:10
有办法安装吗?
因为某些不可描述问题,pip源间歇性抽风,你可以试试换个夜深人静的时间....网速好的时候
 楼主| 发表于 2019-1-23 23:41:33 | 显示全部楼层
快乐之源 发表于 2019-1-23 20:07
因为某些不可描述问题,pip源间歇性抽风,你可以试试换个夜深人静的时间....网速好的时候 ...
请指教下代码 我是小白
发表于 2019-1-24 00:17:01 | 显示全部楼层
zzx386 发表于 2019-1-23 23:41
请指教下代码 我是小白
就是重试啊....
GMT+8, 2025-12-24 09:30 , Processed in 1.222322 second(s), 8 queries , MemCached On.
